Rims, tires and Dana 60 front hubs
Old 07-06-2007, 06:28 PM
Manwith3fords's Avatar
Manwith3fords
Manwith3fords is offline
How big of a tire can you put on a stock 16" F350 dually rim?...31"x10.5" or 33's? Also the same question for the stock 8 bolt regular style rim. I'm starting to build a 1996 F350 crew cab diesel 4x4 (2wd to 4wd conversion) but I'm trying to decide on wether to go dually or not. I don't offroad much, mostly will use my truck for a daily driver, towing a car trailer, hauling firewood and landscaping type materials....But I still want to lift it atleast 4" and make it agressive looking. I have a donor 89 F350 dually 4x4 for parts so I can go either way.
My next question has to do with hubs, the 89 donor Dana 60 front axle has dually hubs on it...It was built with 8R-19.5" tires Will a regular 8 bolt wheel fit on it and if so how much wider would the track be versus the regular 8 bolt Dana 60 hub?
Old 07-24-2007, 09:03 PM
amish77's Avatar
amish77
amish77 is offline
The rim shouldn't be the issue. Rubbing the truck should be the issue. Duallys have a better time in the mud as they cut a wider track, but narrow trails are their acillies (sp?) heel.
Old 07-25-2007, 04:37 AM
Manwith3fords
I'm still doing this swap, but to a 91 F250 XLT Lariat instead. I trade my 96 F150 for it...It has a 7.3/auto.
Old 07-25-2007, 05:09 PM
amish77's Avatar
amish77
amish77 is offline
Gotcha, The 7.3's a strong motor. Good luck with it..
Old 07-25-2007, 05:42 PM
Manwith3fords
408,000km on it and it runs like champ.
Old 07-25-2007, 06:03 PM
amish77's Avatar
amish77
amish77 is offline
man that's insane. My 300 was on the way out after what I believe to be around 300k mi.
Old 07-25-2007, 06:14 PM
Manwith3fords
Hard to kill an IH diesel, especially the 466's and 444's....
Old 07-25-2007, 07:04 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
I can only comment on the Dodge ones I have taken apart. Once you get the hub off, it is a regular Dana underneath and a regular rim will fit. Basically just a spacing adapter that mounts over the lugs to push the rim farther out.
Old 07-25-2007, 07:07 PM
Manwith3fords
I was told the front hubs are not dually hubs...The dually hubs would be almost flush with the rim where as my donor hubs stick out past the rime 4" or so.
TAT2DUP81
07-17-2011 01:24 PM
F250FarmBoy
44
03-26-2009 06:27 AM
bigsub
1999 to 2016 Super Duty
28
01-20-2009 03:29 PM
markjw
08-04-2006 07:06 PM
supercab4x4dually
01-01-2004 12:53 PM
Quick Reply: Rims, tires and Dana 60 front hubs
