7.3 vs. 6.0
Old Jul 5, 2007 | 09:30 PM
Fifty4F100's Avatar
Fifty4F100
7.3 vs. 6.0
Which is the best PowerStroke? I'm hearing both on and off this forum that the 7.3 is lightyears better.
Old Jul 5, 2007 | 09:34 PM
rollerstud98's Avatar
rollerstud98
thats a matter of opinion, the 6.0 was plagued early with some problems but has turned into a very strong motor, out of the box the 7.3 will not touch the 6.0 in any single aspect except making more noise, the 6.0 with the torqueshift tranny is lightyears ahead of the 7.3 with its auto, no comparison really.
Old Jul 5, 2007 | 09:38 PM
Kep4's Avatar
Kep4
Jäger
Why do you ask? Are you considering a purchase? If so, what will you use the truck for? Specifics would be most helpful in answering your question.
Old Jul 5, 2007 | 10:15 PM
UGA33's Avatar
UGA33
On the performance side of the spectrum, the 6.0L wins every category. Reliability side would have to go to the 7.3L. When you add in the emissions stuff and the issues the vgt turbo is prone to, 7.3L wins this aspect. I think if the 6.0L is maintained properly, it will run just as long as a 7.3L will. I think if you were to punish both motors equally, ex (running it over oil and fuel filter change intervals, extended idleing, running hard and then shutting down w/out cooling down, etc.) the 7.3L wins. I think the torqshift tranny makes the 6.0L just as appealing as the 7.3L along with the new frame on the 05 and up trucks and the tow command, which is the best thing since sliced bread in my opinion.
Old Jul 6, 2007 | 01:34 AM
BC Powerstroke's Avatar
BC Powerstroke
7.3L has a great legend for bullet proofness and good engine life. However it does not compare to the power of the 6L particulalry pared with the torqueshift tranny.
The 6L plagued problems appeared in the early models (03-05) and it generally was associated with a the new emmisions equipment the 7.3L did not have. I am of the opinion you rip all this emmision stuff out or disable it, the 6L may get the reputation of the 7.3.
However keep in mind replacement parts for the 7.3 is cheaper than the 6L which is attrative for cost effective maintenance. Prolonging the old truck life to "death do us part" is usually cheaper than buying a new truck particulalry these days. See the price of the 08's. Ouch............
Time will tell on how the 6L life compares to the 7.3L. In general most will agree the 6L is like a hot girl friend - higher maintenance to keep it running it top condition.
Old Jul 6, 2007 | 06:02 AM
msgtg's Avatar
msgtg
Glen the one thing I tell everybody is to get an OASIS report on the truck to see what's been done to it. If it's been in for consistant maintenance (and yes, there are some of those out there!) I'd find a different truck. But, like in my case, I found one with 34K on it with a no powertrain maintenance history...and I bought it.
Personally, my 2003 6.0 has 47K problem free miles on it.
Joe
Old Jul 6, 2007 | 08:51 AM
kw5413's Avatar
kw5413
Joe
The OASIS very, very important on the 6.0. Best advice to follow. My '04 was virtually flawless BTW. Sure do miss it.
Old Jul 6, 2007 | 04:24 PM
Fifty4F100's Avatar
Fifty4F100
Joe
I saw the OASIS sticky thread. What is that?
I can get a 97 F250 with the 7.3 and 5 spd. for $8500. KBB says that's about even for personal sale. It has 152K miles on it. I plan on hauling an RV mostly and now tow horse trailer and paraphenailia.
Old Jul 6, 2007 | 04:28 PM
OZX1's Avatar
OZX1
I can get a 97 F250 with the 7.3 and 5 spd. for $8500. KBB says that's about even for personal sale. It has 152K miles on it. I plan on hauling an RV mostly and now tow horse trailer and paraphernalia.
Basically, it's the Ford dealership maintained health record for the truck. The information is dealership only service information, so if it got some stuff done to it at the local garage, or in the guys back yard, that's off the record...
Old Jul 6, 2007 | 04:50 PM
Fifty4F100's Avatar
Fifty4F100
So just call a Ford dealership with the VIN and out spits the info? Is a Ford dealership a good place for diesel work?
Old Jul 6, 2007 | 05:24 PM
OZX1's Avatar
OZX1
You can go the the OASIS thread and make your request there, or you can go to Ford. As for Ford being a "good place" for diesel work, that is subjective. If you want to pay the dealership prices, and IF they have a diesel tech that's any good, then yes, a dealership is a good place. That same logic applies to where ever you go for diesel service. There are some brilliant techs out there that don't work for Ford, or charge like they do. While I'm under the 5/100 warranty, I'm a dealer guy. After that, I'll have to either be a DIY'er (like on most of my stuff) or do my research on other options. There are no slam-dunks on this question...
Old Jul 6, 2007 | 05:32 PM
kw5413's Avatar
kw5413
Not sure but, OASIS may not be available for a '97.
Old Jul 6, 2007 | 05:34 PM
thorseshoeing's Avatar
thorseshoeing
decadent and depraved
I don't know, maybe I just got lucky and ended up with a great 6.0, but I run my truck hard (overloaded alot of the time), I change my oil whenever I get around to it, anywhere from 6-10000 miles (usually around 8000) It's normal for me to let my truck idle for 30mins to an hour a day, and when I do shut it down I never wait for it to cool down. Been doing that for over 93,000 miles now and not one single problem...Like I said, I guess I'm just lucky.
Tim
Old Jul 6, 2007 | 05:42 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
go find a stock 7.3 & a stock 6.0 & drive them both.
then make your choice - chances are you will pick the 6.0
Old Jul 6, 2007 | 07:07 PM
Fifty4F100's Avatar
Fifty4F100
The 6.0s being 03 and newer, they are pricey!
The main reason I am asking about mechanics - there is a thread on the Tennessee chapter asking for good diesel mechanics in Memphis - I have become interested!!
