Bronco II Ford Bronco II
power booster
Old Jul 5, 2007 | 07:31 PM
dogg16's Avatar
dogg16
power booster
is there an adjustment i can make on the brake power booster??i read somewhere here that the pushrod was adjustable..if thats the case it would account for the excessive travel in the pedal..anyone know how to adjust it??
Old Jul 5, 2007 | 11:24 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I don't remember mine being adjustable. Lots of reasons for excessive pedal travel. Worn Brakes, Adjusters not adjusting, Master cylinder going bad, etc...
Old Jul 6, 2007 | 12:56 PM
kernel-panic's Avatar
kernel-panic
I don't think it would be on the power booster itself, but rather the pedal linkage. I've never heard of any adjustments for pedal travel on the brake pedal, but that doesn't mean it's not possible.
Old Apr 25, 2012 | 07:03 PM
danboy282's Avatar
danboy282
yes there is
On my 86 b2, if you take the master cylinder out you can see a pushrod. It has a small ball nut type thing that you can loosen to make the pushrod longer. Be careful though it can't be too long or you will damge your master cylinder.
Old Apr 26, 2012 | 07:54 PM
critterf1's Avatar
critterf1
Are the rear shoes properly adjusted?
Old Jun 1, 2012 | 09:42 AM
broncoman87's Avatar
broncoman87
Power booster
Just wanted to add a little tip Ipicked up after you bolt your brake master cylinder up put a bead of silicone around it this keeps water out and will extend the life of your brake booster. They like to rust out behind the master cylinder.
Ckingsalem
Oct 12, 2013 08:50 PM
Heirloom
Feb 11, 2013 09:47 AM
78workhorse
Oct 3, 2009 05:58 PM
jmf66
Apr 11, 2009 09:50 AM
Dylansdad
Mar 26, 2007 08:43 PM
