ATOMIC BACKFIRE
Old Aug 13, 2002 | 10:40 PM
hairball12's Avatar
hairball12
ATOMIC BACKFIRE
I went from the frying pan to the fire with this one.
After replacing a carb that was causing problems, hard starting,
stalling, leaking, then a fire. I wound up with a new problem.
When I let off the gas at high speed I get one single large backfire.
The other prombles are gone and the truck runs good except for the backfire.
There is a condenser mounted to the coil but the wire got burned in the fire and I am not sure what the wire was connected to. Could this be the problem? Do you know where that wire goes? Thanks
Old Aug 14, 2002 | 06:08 AM
rabidranger's Avatar
rabidranger
ATOMIC BACKFIRE
Is it a backfire through the exhaust or the carb? If it is through the exhaust you may be running to rich, and when you let off the gas all the unburned fuel in the exhasut gases will ignite in your tailpipe, and BOOM, big ole backfire. Check your carb for proper jetting and tuning.
Old Aug 14, 2002 | 09:00 AM
Brian460's Avatar
Brian460
ATOMIC BACKFIRE
The condensor should be hooked to the postive side of the coil. It is part of the radio noise suppression, not having it connected will not cuase it to backfire.
Brian:-)
Old Aug 14, 2002 | 01:24 PM
hairball12's Avatar
hairball12
ATOMIC BACKFIRE
The timeing is good and the backfire is from the exaust.
Old Aug 14, 2002 | 05:05 PM
hairball12's Avatar
hairball12
ATOMIC BACKFIRE
Any body know of a good source of info on stock jetting
for a holly 4Barl 4180-c????? Thanks
Old Aug 15, 2002 | 07:02 PM
flyboy2610's Avatar
flyboy2610
ATOMIC BACKFIRE
JeepScrambler
Oct 24, 2014 10:18 AM
ColtonMullis
Dec 31, 2013 07:56 PM
Unegawahya
Aug 31, 2010 01:24 PM
special_k
1978 - 1996 Big Bronco
Apr 27, 2009 10:07 AM
Bruce C
Apr 2, 2005 10:54 AM
