Trailer Towing limits
Old Jul 5, 2007 | 10:09 AM
tornade's Avatar
tornade
What would be the longest travel trailer to safely pull with my 06 F150
4.6 V8 SCAB, w/towing package.
Old Jul 5, 2007 | 12:10 PM
irishammer's Avatar
irishammer
The length of the trailer doesn't matter, it is the weight of the trailer. Lots of the newer trailers are very lightweight compared to several years ago. Look up your axle ratio and tire size along with 4.6L and determine the max weight from there. You should be able to find that info in your owners manual.
Old Jul 5, 2007 | 03:09 PM
tornade's Avatar
tornade
Thanks irishammer, I will check the owners manual.
Old Jul 5, 2007 | 03:13 PM
theisen_4's Avatar
theisen_4
Here's a rule of thumb about wheelbase and trailer length:
For the first 110" of wheelbase, this allows you 20' of trailer.
For each additional 4" of wheelbase, this gets you 1' more of trailer.
http://www.rvtowingtips.com/how-long.htm
Old Jul 6, 2007 | 04:22 PM
tornade's Avatar
tornade
Thanks Theisen 4 your help and that great link
rt
Old Jul 6, 2007 | 04:25 PM
77redtruck's Avatar
77redtruck
What is the towing weight for a Ford Explorer?
Old Jul 6, 2007 | 04:42 PM
tornade's Avatar
tornade
V6 4X2 is 3500 Lbs (2007)
http://www.fordvehicles.com/suvs/exp...eatures/specs/
Old Jul 6, 2007 | 06:05 PM
last5oh_302's Avatar
last5oh_302
Up to 7300 lb's with a 4x2 V8.
Old Jul 6, 2007 | 06:37 PM
thechief96's Avatar
thechief96
Also remember that what you have in your truck needs to be included into the final calcs.
Old Jul 6, 2007 | 06:40 PM
ford390gashog's Avatar
ford390gashog
That only needs to be added when finding GCWR.
Old Jul 6, 2007 | 08:44 PM
Brolli's Avatar
Brolli
so when it states my truck can tow 9800lbs. my bed can be loaded and cab be filled with all 6 people and still tow 9800lbs. i have a 07 150 hd.
Old Jul 10, 2007 | 03:58 PM
theisen_4's Avatar
theisen_4
From what I have learned, the 9800 lb towing rating is for a stripped down truck with a 150 lb driver. Anything else added to the truck (passengers, cargo, etc.) will reduce the towing capacity by the amount of the additonal weight.
Old Jul 11, 2007 | 01:34 PM
pjbonthebeach's Avatar
pjbonthebeach
Greetings, all. I live in Florida and just finished a 700 mile round-trip drive to Key West towing my 4500 lb pontoon boat/tandem-axle trailer. I have a stock '05 Lariat SCrew with the 5.4 (63k miles) and according to the onboard computer, which I have found to be fairly reliable, here are the stats:
70 MPH - 7.5 mpg
67 MPH - 9.0 mpg
60 MPG - 12.5 mpg
The speed was tested for a minimum of 50 miles for stabilization. Not very appetizing or admirable for FOMOCO. There really needs to be a diesel option in the 150.
John
Cape Canaveral, Florida
1946 Ford 1/2t pickup
1955 Ford Sedan Delivery (for sale)
2005 Ford F150 Lariat SCrew
Old Jul 11, 2007 | 02:34 PM
KevinM's Avatar
KevinM
The frontal area of the tow also matters. Ford specs to 60 sq ft of frontal area for the F150. Looks like max tow weight for the 4.6 with tow package and 3:73 rear gears is 7100lbs. Keep in mind as you load the truck up you have to subtract from the max tow weight. Tow weight is speced based on some assumed loading of the vehicle. Anything past that assumption requires you to subtract from max tow weight.
The tow weight is calculated off the GCWWR. So if the GCWWR is say 15,000lbs and you tow 9800lbs that leaves 5200lbs for the total truck weight.
Old Jul 12, 2007 | 06:14 AM
bigdavewilson's Avatar
bigdavewilson
Simple answer. NO!!
With 6 people and a loaded bed you are probably at or over the GVWR which should never be exceeded. In other words, you can probably safely tow nothing. Fords towing trucks are the F250 and F350.
Oops, just noticed those two little letters "hd". I should have said Fords towing trucks are the F250 and F350 and the F150 with the HD package. Congratulations on finding an HD truck and having the sense to buy it. They are really hard to come by here in Canada. The local dealer where I bought my truck has pretty well given up trying to get them and they sell a lot of trucks.
When I visited the other dealer in the city they were quite adamant that Ford doesn't make an HD F150.
The reason that I have maintained an interest in the HD package trucks is that the first new series F150 I ever saw was a Scab HD. It was in Flin
Flon, Manitoba and I still wish that I had bought it. As they say, "too soon old and too late shmart"
