Generator light on ALL the time...
'don't have a repair manual, but have checked:
*the battery: 12.67 V - does not change voltage when the engine is revved
*fan belt for the generator: it's tight and it spins the gen.
*the voltage regulator: the bottom "coil" connects to the battery and then pushed in the GEN light goes out, but the voltage does NOT increase (at the battery) when the engine revs
...so, how do I check the VOLT.REG, and GEN to determine which is not working properly? Is there a way of "adjusting" the VOLT.REG.? I'm "in-the-dark" without "maintenance procedures" - I'm willing to fix it, I just don't know how...
Thanx,
Ron
</TD></TR></TBODY></TABLE>
</td></tr></tbody></table>Sounds like your Volt. Reg. is not grounded any more. Try taking all the mounting screws out and then screwing them back in.
This will fix it a lot of the times, you get the same result by replacing the Vol. Reg. but this way is cheaper.
If you do replace it do not forget to polarize it.
