Fuel Injected 347 Stroker?
Old Jul 16, 2010 | 06:57 PM
littlecountryboy89's Avatar
littlecountryboy89
i want to make my 302 a 347 stroker but any one i talk to at jegs or summit says that it cant be done with speed density!! but from what you guys are saying it is possible u just have to have the computer re programed to accept the mods. where can i have it re programed. any other info would also be greatly appreciated.
Old Jul 19, 2010 | 08:14 AM
Conanski's Avatar
Conanski
Originally Posted by blu93gt
[updated:LAST EDITED ON 23-Aug-02 AT 01:33 PM (EST)] aftermarket MAF's come calibrated for whatever size injectors you want, so no computer reprogramming or custom chip burning or anything like that is needed.
No that's a misconception, the further away from stock the motor is the worse it runs with this "calibrated" injector/MAF trick. Anybody that has one of the tuners now available for these vehicles will tell you how much better the engine runs when tuned, simply because you can change the critical parameters the computer uses to make it's calculations. The fuel requirements for a deep breatrhing stroker are very different than a stock 5.0 and simply scaling up the injectors capacity across the board doesn't work very well anywhere except WOT.
Old Jul 20, 2010 | 05:52 AM
littlecountryboy89
thanks alot for the info!!
xtraparts
Nov 5, 2014 10:12 PM
GM4WALLS
18
Oct 11, 2013 07:41 AM
MonsterTruck\m/
Nov 21, 2011 03:46 PM
Country705
22
Aug 19, 2010 09:44 PM
pavlaker
Mar 18, 2008 11:45 PM
