Boost question
Old Jul 4, 2007 | 03:30 PM
mndiesel's Avatar
mndiesel
Boost question
I am only showing 2lbs of turbo boost at 65 on the highway with the cruise on. Is that normal or low. I thought I read somewhere on here you should get 6-7 lbs of boost at highway speed. Thanks Tom
Old Jul 4, 2007 | 04:03 PM
IDPisan's Avatar
IDPisan
That does sound a bit low. I see you have the over boost eliminator, after I had put mine in I didn't get the connections tight enough and it was not reading properly. So if evewrything else is tight you may want to check it out.
Old Jul 4, 2007 | 11:09 PM
bdrummonds's Avatar
bdrummonds
Tom, How many miles on the truck. I too am going through a low boost prob right now and I have narrowed mine down to the waste gate actuator. My actuator rod is tight, but I think the spring inside the actuator housing has become weak and is letting my exhaust push open my WG a little thus creating a lower overall boost. I am seeing 3-5 psi at 70mph and can only acheive 18-20 at WOT thru the gears. And if I unplug the red line to the actuator it makes no difference in the above WOT number.
Old Jul 4, 2007 | 11:45 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
At 65 to 70 mph I usually see between 6 and 8lbs.
Old Jul 5, 2007 | 06:39 AM
Kwikkordead's Avatar
Kwikkordead
Leaky up pipes.
Old Jul 5, 2007 | 07:16 AM
mndiesel's Avatar
mndiesel
I have 80900 on the dial. Thanks for the info
Old Jul 5, 2007 | 07:17 AM
mndiesel's Avatar
mndiesel
Originally Posted by Kwikkordead
Leaky up pipes.
Thanks I will check that out today.
Old Jul 5, 2007 | 08:23 AM
HKusp's Avatar
HKusp
I am seeing only 4-6 lbs at 60-65mph. At WOT I have only seen 16lbs although I haven't really got on it on the highway. I will today and see what happens.
Old Jul 5, 2007 | 09:10 AM
rbaker6336's Avatar
rbaker6336
My actuator rod is tight, but I think the spring inside the actuator housing has become weak and is letting my exhaust push open my WG a little thus creating a lower overall boost. .
when I replaced my torbo one of the things I noticed was that the actuator spring was considerably weaker than the new one,this was at 118k mi
I took up a little more on the new one,not sure if it will help
Old Jul 5, 2007 | 01:42 PM
HKusp's Avatar
HKusp
Okay, maybe 4 lbs at 65mph and I saw 17 lbs at WOT up 80 mph. Is that low? Truck is stock except for the 6637 and has 67,400 on it.
Old Jul 5, 2007 | 01:46 PM
Izzy351's Avatar
Izzy351
I don't think that's low for stock. I wish I could go out and test it, but my wife won't quit driving it!!!
This is getting bad. She's got a relatively new (2006) Mitsubishi Durocross, too. Anyone want to trade a low mileage (10k) Durocross for something with a 7.3??
Old Jul 5, 2007 | 02:09 PM
7.3L DID TD's Avatar
7.3L DID TD
IMO the way the gauge is connected and the manufacturer of the gauge will cause some variance in readings. At maintenance throttle at 70MPH I see about 4 or 5#'s boost while in DP-Tuner setting 80economy, but as soon as the truck starts climbing a grade I see as much as 14#'s. Now if I'm passing some Duramax or Cummins I have seen 26#'s.
