Injector/Turbo replacement
Old Jul 4, 2007 | 10:19 AM
Toyhauler5's Avatar
Toyhauler5
Just took my 6.0L in for maintenance at an indepndant shop. It has 99K miles. I was told I have 2 bad injectors (poor performance on cold engine). Since it is still in waranty (barely)he suggested I replace the injectors now at a ford dealer. I also asked him about the turbo since I heard others have lots of failures with this. I have not had any problems and have my original still running. He said to try and have the dealer replace the turbo under warranty too, even though he could not find anything wrong with it. Does anyone recommend for or against replacing a turbo that has no apparant problems? I have heard horror stories about ford replacing turbos with remanufactered units, only to have them fail a few thousand miles down the road. Is this something I should mess with?
Old Jul 4, 2007 | 10:53 AM
heavyiron's Avatar
heavyiron
If there's no problem with the turbo, why would you expect Ford to replace it?
Old Jul 4, 2007 | 11:03 AM
Toyhauler5's Avatar
Toyhauler5
The mechanic knows the guy from the ford dealership and seems to think he will replace it since its warranty work and they work on commission. Sounds strange huh?
Old Jul 4, 2007 | 12:30 PM
fowlerford56's Avatar
fowlerford56
oops hit return too quick. anyway the phrase, "If it ain't broke, don't fix it" comes to mind....
Old Jul 4, 2007 | 01:23 PM
diesel_dan's Avatar
diesel_dan
Somewhere here I read a post of the service instructions Ford uses for the 6.0 turbo. The first attempt is usually cleaning the turbo, as I recall. There was an upgrade to the turbo at the end of '05, so not sure when yours was built. The upgrade was extra machining done to prevent sticking vanes. If they'd upgrade you to that unit, it would be nice as there's been very few reports of vane problems on those trucks built after the changed turbo made it into production...
Andrewdavis34
Apr 13, 2013 09:16 AM
lauraj
Feb 23, 2011 01:23 PM
lauraj
Feb 14, 2011 12:27 AM
vlietracer64
Feb 11, 2008 12:56 AM
Brimhall
Dec 31, 2003 09:36 AM
