Front suspension woes..
Old Jul 4, 2007 | 07:49 AM
bucktaylor's Avatar
bucktaylor
2001 Exped. with air shocks.
At highway speeds (60+ mph) if I hit a bump/pothole with only one of the front wheels I get severe wheel hop. Which takes a good 2-3 seconds to smooth back out. Really scary in a high speed corner.
Rotated the tires and it still does it.
Took it into the shop and all front end parts are tight and good, they suggested it might be the air shocks.
Would bad air shocks cause this type of handling problem?
I'm thinking to order new front ones from American Air Susp. when they get back in stock in mid-july.
Anyone with similar experiences?
Old Jul 4, 2007 | 05:12 PM
Trucker22's Avatar
Trucker22
suspension
You don't say mileage---but being an 01 assume it's over 60K---mine is 00 and have 90K on it---just replaced the front air shocks and rears too---what a difference---I didn't have the bad wheel hop you have but cornering was beginning to be challenging especially when towing---unfortunately those front air shocks are pretty specialized---I bought the Monroe OEM---not from the dealer---shockwarehouse I think---wasn't too bad to replace---well worth it and you will be amazed at the improvement. Good luck---let us know what you do
Old Jul 5, 2007 | 06:12 AM
bucktaylor's Avatar
bucktaylor
Thanks for the info....just ordered a pair from shockwarehouse.
I am hoping these will make the difference. Milage is about 106K so they are due for replacement.
I'll post back after install w/results....
Old Jul 26, 2007 | 04:20 PM
bucktaylor's Avatar
bucktaylor
Installed new front air shocks. The death wobble seems to have been cured as well as the wallowing over bumps at highway speeds.
Install was pretty easy ,
-Shut off air suspension switch in the passenger foot area
-To disconnect the air line from the shock, push in the colored ring with a small flatblade screwdriver and then pull the hose out. I used two small screwdrivers, one on each side of the ring to push it in.
-Remove bolts and take out shock.
basement pro
May 19, 2013 09:38 PM
ARK Ranger
Jul 18, 2011 08:22 PM
ChambersF150
1997 - 2003 F150
Nov 30, 2009 07:27 PM
RigET
Apr 23, 2009 06:30 PM
blackbast
Dec 15, 2004 07:39 PM
