So me and the person who is gonna post next notice a problem... We lost a quart of oil. I'm leaking a little. But he isn't. Anybody know where that other qquart went?
Oil filter takes up about 1/2 quart or so. It doesnt really run back into the pan because of the angle the filter is on. If you are talking about your truck in your signature, it should only take 5 qts plus a filter full.
You check dipstick. Dipstick says full, that means there is 6 qts.
You drain oil, get 5 qtz.
That means there is an extra qt in there.
Where is my missing qt?
Okay, yes your theory is plausable. But if there is gunk, or sludge remaining.
That means i will only be able to put 5 qt's back in. When i refill, takes 6 qts.
I'm running seafoam in there also, so there is no crud, or sludge. The oil looks like dark honey comming out, not even black, or crude looking.
So, how can you drain 5, but put 6 in?
Makes me think engine holds 7.
And you always have a qt in there even when you drain, thus getting 5, and when you add six back, 1+6 = 7.
