Front Steering Torque Questions ??????
Old Jul 3, 2007 | 06:32 PM
The67Beast's Avatar
The67Beast
Hi Guys,
This question is specific to my 1967 F-100 4X4. No two-wheel drives here...
I am installing a new Drag Link and Center Link onto my truck and cannot seem to find the torque specifications for the ball joints. Since this is my first time doing steering parts, I wanted to do it correctly. I would rather that they are not loose and break going down the road! I have searched thru my manuals and cannot find the specifications for these. Can anyone out there lend me a hand in this area. How tight do I tighten these before putting the cotter pins back in ??? Should I use some washers or spacers ???
Thanks a million.
Old Jul 4, 2007 | 08:48 AM
FordBoypete's Avatar
FordBoypete
By Ball Joints (?), I'm gonig to presume you are talking about the pivoting tie rod ends with tapered shafts connecting steering linkage to steering knuckles & pitman arm.
Based on that; They are a tapered fit, with either a 7/16 or 1/2 NFT thread. Therefore I'd tighten 1/2" dia's to +60#s & 7/16ths to +50#s, San's washers or spacers. Just run the nut down to the forging. It should be machine finished for that very purpose.
Also, if you're about to hit your desired torque spec but the cotter key hole is already lined up, quit & install the cotter there. I do it that way all the time with good results.
Reason I do that is I don't want to over tighten & I sure don't want to back off after I tightened the nut down,. So undertightened, but close within a few lbs torque is best alternative to me.
I hope this helps you out. BTW I just came thru your neck of the woods yesterday.
FBp
rottenstock
Jun 2, 2013 07:31 AM
rbhug
Nov 12, 2012 12:04 PM
AzSuperDuty
Apr 3, 2012 03:01 PM
rbhug
Dec 1, 2010 11:11 AM
offroadjunkiex
Jul 27, 2003 06:40 AM
