Cruise Control/Swap
Old Feb 4, 2008 | 04:06 PM
Mil1ion's Avatar
Mil1ion
The 76 and 77 boosters are different and 77 will not work in a 76 without fabrication.
The steering columns are NOT wired for cruise
The special wiring HARNESS Before it hooks to the column wiring is what allows for cruise control.
You see Ford allowed for the adaptation for cruise with minimal changes
The trucks that got cruise control used the normal horn circuit to power the cruise buttons and then used another circuit with a relay to power the horns.
You can see the difference how the cruise/horn pad hook to the steering wheel
compared to Non-cruise horn pads
Let's hope you got that as well
Old Feb 4, 2008 | 04:31 PM
tx78's Avatar
tx78
This is interesting my 78 150 has the equipment and uses the the blinker for the controls. It doesn't work though, anyIdea of where I should start?
I work at a dealership as a driveabilty tech helper. Two guys out of the dealership have worked on a trucks this old.
Old Feb 4, 2008 | 04:47 PM
Woodyp's Avatar
Woodyp
so do I need the booster?
If I understand, I don't need the column or the steering wheel from the donor just the horn pad with the switches and the pigtail wiring that plugs in between the standard cab wiring harness and standard steering column wring harness. I got all that.
the only other thing I didn't get that was on your list is the horn relay and wiring. is that under the hood?
Old Feb 4, 2008 | 05:27 PM
Mil1ion's Avatar
Mil1ion
You need the 76 booster and probably the pedal assembly
This should help.
Old Feb 4, 2008 | 05:53 PM
Woodyp's Avatar
Woodyp
wow, great info.
so am I right that I don't need the donor's steering colum and steering wheel, just the horn pad with the switches?
Old Feb 4, 2008 | 06:00 PM
Mil1ion's Avatar
Mil1ion
Correct.
make sure about power brakes and special brake pedal.
It appears I forgot to photograph and label the under hood parts
Old Feb 4, 2008 | 06:02 PM
Woodyp's Avatar
Woodyp
I also can't help being curious about what the difference is between cruise and non-cruise boosters are, if I go to advanced auto and look up a booster it list the same booster fits:
1978 BRONCO
1977 - 1979 F-150 PICKUP
1977 - 1979 F-100 PICKUP
1977 - 1979 F-250 PICKUP
Old Feb 4, 2008 | 06:16 PM
Woodyp's Avatar
Woodyp
I just looked at the cruise wiring harness I have and it does not include the horn relay. I remember that for harness and boxes I have pulled from 78-79's. Would you know where the horn relay is on the 77?
Old Feb 4, 2008 | 07:16 PM
Mil1ion's Avatar
Mil1ion
On trucks with cruise it is usually attached to the dash board brace.
Old Feb 4, 2008 | 09:31 PM
Woodyp's Avatar
Woodyp
Yea, I under stand what your saying because I've seen it on later model trucks but my harness doesn't have the plug.
Old Oct 7, 2008 | 11:46 PM
okwaho1650's Avatar
okwaho1650
So the steering wheels are the same
