So my engine threw a code for Glow plug #7 just recently. I prepared myself with new glow plugs and a valve cover gasket to do only the side with the bad glow plug. I've got two questions:
Cyl #7 is in fact on the driverside correct?
And...
After installing new glow plugs on the driverside and clearing the code, the code came back. I obviously didn't fix the problem so are there tests I can run on the harness? voltage test maybe? I assume it's either the glow plug/injector harness or whatever that's connected to.
