Radiator questions
Old Jul 3, 2007 | 09:16 AM
AirSmitty's Avatar
AirSmitty
Radiator questions
Hey guys I've got a 78 f250 4x4 that came with a 351m and somewhere along the line it had a 460 swapped into it. I'm pretty sure its still got a 351 sized radiator and i'm running a 5 blade flex fan. I've come very close to overheating a couple times and its 100+ around here this time of year so i've decided to order the super cooling 4 row radiator that I've seen people talking about. so on with my questions. Where's the best place to get one? Will I have any issues with fitment due to the 460 swap? And what's the difference between an A/C radiator and one for a truck without? My truck has an aftermarket A/C system so i'm not sure which radiator i should order.thanks in advance!
Old Jul 3, 2007 | 11:21 AM
beartracks's Avatar
beartracks
Be sure to use a shroud or you will lose a lot of the benefit.
Old Jul 3, 2007 | 12:34 PM
ford390gashog's Avatar
ford390gashog
I asked Number Dummy about the 4 row supercooling and he said it was discontinued in 88 and no longer sold. You best bet is to get one in a junkyard and have it recored.
Old Jul 3, 2007 | 12:57 PM
czaroc's Avatar
czaroc
There is a difference between those with AT vs MT I believe
Old Jul 3, 2007 | 06:25 PM
fasthauler's Avatar
fasthauler
There are several models of the new cross flow radiators available. They are a heck of a lot more efficient than the old down flow factory types. FTE site sponsors have them, just go up and click on one. If you want to retain the stock appearance go to radiator shops in your area. They can be quite helpful if you can find an old time radiator shop with a guy that likes to talk.
Old Jul 3, 2007 | 06:52 PM
IowaTower's Avatar
IowaTower
I think the big difference AC vs. non-AC is the number of cores.
Old Jul 3, 2007 | 07:52 PM
Phinxter's Avatar
Phinxter
did you ever consider an electric fan? put a pusher in front along with the engine driven fan, bet that would even make your a/c work better
Old Jul 3, 2007 | 11:52 PM
AirSmitty's Avatar
AirSmitty
Well after some poking around here i've read that flex fans don't work very well at slow speeds, or at any speeds for that matter. I think i'm going to go with a dual electric puller setup. I've always kinda wanted to do it so now i have a better excuse than i've ever had before haha.
Old Jul 4, 2007 | 01:13 AM
fasthauler's Avatar
fasthauler
Good move, flex fans really pull a lot of air, but I found out the hard way that they aren't worth a hoot when towing. If you are climbing a steep grade in low gear the engine is revved up and the flex fan flattens out and doesn't move any air. Plus the fact that you are probably moving slow so the vehicle speed wont push any air through the radiator. This causes major overheating. Plus the fact that they are downright dangerous. I have a nice bulge in my hood from a flex fan loosing a blade. I was darn lucky that all I lost was a fan belt and a couple of radiator hoses.
Old Jul 4, 2007 | 01:32 AM
Torque1st's Avatar
Torque1st
Posting Legend
Use at least a three core radiator as big as you can get. A 4 core radiator does not add 25% to your radiator capacity over a 3 core unit, -more like 10%. Use a regular duty thermostatic clutch fan with a full OEM shroud that fits the fan and radiator. A heavy duty thermostatic clutch unit can increase cooling capacity but will increase noise levels. A pusher electric fan is a good addition if you find your cooling system is marginal. There are a number of other things inside the engine like rust/scale that can severely impact cooling system capacity. The flex fans work OK for a racer but are worthless for a working truck.
Old Jul 4, 2007 | 03:05 AM
czaroc's Avatar
czaroc
Side note: If you can get your hands on some GOOD de-ionized water, run a gallon through your engine. Not for long... just 15 minutes or so. Cleans the rust/scaling right out.
If you leave it in too long, it'll clean your head gaskets right out too ;-)
Old Jul 4, 2007 | 11:35 AM
mark a.'s Avatar
mark a.
The 4 core looks like it would be awful close to the steering box. I've seen pictures with them in there but I don't know what would be involved in getting one in there because they never came in a 77.5-79 4x4 truck + the different core support types. You would have to get the right mount type for your support. I priced one localy not long ago it was 238$. The only other option was getting mine recored to 4 core which was real pricy but then I'd know it would slip back in with no problems. More than one person has told me the Royal Purple additive was well worth putting in.
Old Jul 4, 2007 | 07:24 PM
mhg's Avatar
mhg
check out rock auto
they have listed a 3 core for your year and engine
Old Jul 4, 2007 | 09:02 PM
deisele75's Avatar
deisele75
I also have a 1978 F250 4x4. Did not come with factory AC. Swaped in a 460. Ordered my radiator from here and it fit perfect. BTW.... It's a Modine 4 core
http://www.radiatorworld.com/radiatorworldFinal/displayProducts.aspx?carno=23659&cat=1
Ordered my fan shroud from dennis carpenter, and i was good to go.
Old Jul 5, 2007 | 06:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No there isn't, only one Super Cooling radiator was offered for all the V8's = D3TZ-8005-G.
Czaroc, the same radiator was used for Extra Cooling as it was for A/C.
What IS different between the Standard/Extra Cooling/Air Conditioning radiators and the 4 row Super Cooling radiator is the core support. The support is different if the 4 row S/C radiator was factory installed. To fit a S/C radiator to a truck that didn't have one, the radiator mounting area must be opened up.
Eric: The Super Cooling radiator core is 2 5/8" thick, while the other cores ranged from 1 1/4" to 1 15/16" thick.
