Another 390 temp problem/question
Old Aug 2, 2010 | 10:09 AM
  #61
GREEN 94 RANGER's Avatar
GREEN 94 RANGER
Originally Posted by Argess
A leaking cyl head gasket can allow cylinder pressure (i.e. exhaust) into the cooling system. This can pressurize the system forcing coolant out the rad cap until there isn't enough left to adequately cool the engine. Sometimes these leaks only show up when en engine is hot, but any rad shop should have a pressure tester they hook up in place of your rad cap. The pressurize your cooling system and make sure the pressure holds and doesn't drop off.
When I fill a dry engine with coolant, I try to remove something high up to help air bleed out. In my case, it's the temp sender unit located on the intake manifold. This shouldn't affect you as you've driven the engine long enough any trapped air bubbles in the cyl heads should have cleared on their own by now. So that doesn't help you at all.
Next time the engine is fully warmed up, besides looking into the rad, check the bottom rad hose. Be careful of the fan, but rev the engine a little while looking at the hose. See if it starts to suck in (collapse) as the rpms come up. You don't have to rev it high...maybe 1500 to 2000 rpm for a second or two. Maybe keep the rad cap on while doing this lower hose check.
Thanks for the help, I will definetly try your solutions, also going to try a larger spacer to move the fan closer to the RADIATOR as someBODY mentioned, can't hurt
TIA
Rich
Old Aug 2, 2010 | 11:24 AM
  #62
merlynr's Avatar
merlynr
That's a good idea. I made an airline connection for doing leak-down tests by welding a fitting to a sparklug shell (porcelain knock out). I coudl use that next time I think I have a head gasket leak. Maybe the OP could make one too (if he has an air-compressor and a welder). It would certainly show up leaks, although there's only a pinhole in the thermostat if its closed, so maybe after the engine is warmed up a bit.
This thread is getting fairly long, but I think someone did mention "fanbelt" and I'm sure the OP has checked it. However I have had fan belts slip even though the tension was correct. They get glazed, or the pulleys get glazed or something.
I just borrowed a "kit" from mechanic friend and it had all kinds of fittings and adapters for most any vehicle.
shooter123
1997 - 2003 F150
Jan 31, 2016 08:19 PM
wyoming4x4
Nov 29, 2014 11:10 PM
gixerbike1
23
Oct 9, 2010 04:19 PM
sfitzgerald351
1978 - 1996 Big Bronco
64
Jan 15, 2005 04:27 PM
fordmando
Mar 21, 2004 12:13 AM
