engine cleaning
Old Sep 25, 2002 | 10:06 PM
rj haug's Avatar
rj haug
Post engine cleaning
I dont know alot about engines so i hope these aren't stuipid ?'s.
When i pulled the motor out i layed it on its side so now oil is coming out from the spark plug holes, how can i clean this out and get it running?
also on a different engine, When i start the motor gas sprays out the air intake tube in the carb. does it need a rebuild? (its a single barrel)
Old Sep 27, 2002 | 05:57 PM
Franklin2's Avatar
Franklin2
engine cleaning
For the motor that has oil in the cylinders. Get it installed, or tell whoever is going to install it, to crank it over with the sparkplugs out till most of the oil comes out. Then install the plugs and get it running.
Old Sep 27, 2002 | 09:15 PM
BlueOvalFitter's Avatar
BlueOvalFitter
engine cleaning
As far as the motor with the oil,install it,find a neighborhood with a bad mosquito problem and start that baby up!!!!
Old Sep 28, 2002 | 09:33 AM
georgedavila's Avatar
georgedavila
engine cleaning
