I found a deal on a tuff country lift kit for my 91 F250 4x4. What extra do I need to buy for this kit to make it work. I already have 315/70's on it so i wont worry about bigger tires for a little while. How much do you think this will cost me?
The kit should include everything you need to install it. You shouldnt need to buy xtra things. If you do I would go with a different kit. i like the skyjacker and superlift beter than T/C
it doest have front leaf springs or a piitman arm or shocks but i should be able to get it for under 300. u still think it is a deal? how much would u pay?
if it doesnt have front springs, the pitman arm or the shocks then all youre left with is the rear lift (springs or blocks, most likely a combo) and the TTB drop brackets. So thats not a great deal.
i put a t/c 4" lift on my f250 i just baught the ttb drop brackets blocks and bushings then had springs made and baught a seperate pitman arm for less than 600
wow you didnt need any brake line or sway bar extensions? if i go with a 4 or 6 inch lift do you think that i will still be able to plow snow or will i need to modify the plow mounts?
