I lifted my 94 with a simple shackle flip in the rear. Cost me $16 and hasn't given me any trouble. The front is gonna make up for all the money saved tho. You'll have to buy new springs and I-beam hinges, about a grand's worth of hardware. You'll also want to get a drop pitman arm. Let me know if you have any questions or want some pics.
Deaver leaf springs. Also you can get factory ford springs that are from different f series that will "lift" it. but anytime you lift their are other things to think about (steering, shocks, driveshafts, brake lines, etc.) Good luck.
94BigRed some pics would be sweet if its not too much trouble and where could I find all the hardware for the front and how much money are we talkin about
As for the back, I can email u a few pics. Its a fairly simple thing. The hardest part is popping off the rivets that hold the swing hanger mount. (rear mount) I used a cutoff wheel to cut a deep X in the head, then chiseled off the quarters with an air chisel. Then you cut out the cupped part of the mount so the hanger can hang thru the bottom. I welded the pieces I cut out back into the corners for extra strength. Just hit me with your email and I'll send u the pics.
Holy jeezus I didnt know you could get u bolts so long... I would love to see that clown stomp on the go pedal in 4WD...I'd bet that front end would wrap around itself in a heartbeat.
