Shake, rattle and roll
Old Jul 2, 2007 | 06:24 PM
vaman4215's Avatar
vaman4215
Was reading some stuff online about vibration ahd shake of the 7.3L diesels...My 88 F250 has a good bit to shake to it when it s running regardless of speed. Is there any easy way to tell if it's missing on a cylinder? I know from having a 5 cylinder Mercedes, if it's missing you'll have more of a vibration and shake out of the vehicle....No fuel coming out the exhaust as from unburned fuel...Just wondering how reasonable could it be for the motor mount going bad to cause a shake??? Have also been told it is louder than it should be...
Old Jul 2, 2007 | 10:51 PM
KJLYPW's Avatar
KJLYPW
Crack the injector line on each injector loose one at a time. A missing cylider will show up as no change when that line is cracked open. Timing advance too far will also create some extra noise and rattle.
Old Jul 3, 2007 | 03:50 AM
vaman4215's Avatar
vaman4215
How is the timing set on the 7.3L ????? Is it like a normal diesel where you loosen the mounting screws on the injection pump and rotate it slightly in one direction??
