Aerostar Ford Aerostar
Auto trans
Old Jul 2, 2007 | 07:46 AM
oh2bnok's Avatar
oh2bnok
Auto trans
I need to change my auto trans fluid on my 90 and can't find out how much tranny fluid I need. I don't have an owners manual and the HAYNES manual doesn't specify.
Old Jul 2, 2007 | 08:26 AM
Bear River's Avatar
Bear River
Former ******
There are other posts on the subject, perhaps on of the guys here will give you a like. I believe it takes 11 or 12 quarts.
Old Jul 2, 2007 | 08:46 AM
Pablo-UA's Avatar
Pablo-UA
The problem is that it is impossible to drain all the atf w/o tranny removing. 3-5 quarts stais inside the tranny and if U drop pan to replace filter less then 9 quarts leak out. Much ATF slowly leaks out of tranny cooler and radiator.....
Old Jul 2, 2007 | 09:21 AM
oh2bnok's Avatar
oh2bnok
Thanks, I'll just get 6-7 quarts and go from there.
Old Jul 2, 2007 | 01:45 PM
lv2race's Avatar
lv2race
Get 3 gallons of fluid, hook a couple of 4 foot long clear hoses to the cooler lines by the radiator and put the other end in a deep pan, start engine for 30 seconds and pump fluid out till it spits. Drop pan, remove remainder, change filter, replace pan with new gasket. Fill through dip stick with 2 gallons. Start and let run for 20 to 30 seconds. Begin filling slowly, constantly checking. It should take 12 to 13 quarts.
Old Jul 2, 2007 | 09:59 PM
oh2bnok's Avatar
oh2bnok
That would probably be the least messy way and would get all the fluid out. THanks
