How can I tell what we have?
Pulled the motor from a buddy's newly purchased 69 F-100.
The motor was siezed so we pulled the heads and oil pan to check it out. Here is what we found.
The bore is 4.125. I can't tell what the stroke is since none of the pistons are at bottom center. Are there any markings on the block to tell me what we have? I see that only the 406 and 428 have a bore of 4.13 and everything else seems to be a 4.00 or 4.05. I measured 5 cylinders and came up with 4.125 (carbon is probably the other .005).
This was reputed as a 352 with "good" 390 heads. The heads are common castings, but I suspect the block is something else.
Casting numbers in some cases will tell you what the block is. And in some not. The casting number is located on the right (pass) side of the block. Some blocks don't have a casting number and others carry a generic number used on lots of different bore blocks. I'd also get the date code and it's below the oil filter adapter pad. Or above it if it's a 63 or earlier block. If there are vertical ribs on the side of the block see fo there are 2 dots under the first number in the date code. Date code will be a number/letter/number(s) marking ex...4J25 or 3B5. By the sounds of it you have a 406 or 428 block. Get the casting numbers and date codes off the heads and intake too. That will help piece the puzzle together. Look for any marking on the crank like 2U, 3U, IU, IUB or a full casting number. Post what you find.
G.
G.
Originally Posted by BadHabitinVA
Got that bad boy cleaned up and measured this past weekend.
4.13 bore with a 3.78 stroke. We have ourselves a home made 410 (69 year model block).
Thanks for all the help guys.
Measure the pistons across the wrist pins.
