292 to a 361
Old Jul 2, 2007 | 02:38 AM
f700's Avatar
f700
292 to a 361
hi all can anyone tell me if the bellhousing on a 292 f700 1963 truck is the same as the one behind the fe 361 truck 1967 ?
Old Jul 5, 2007 | 12:14 PM
Freightrain's Avatar
Freightrain
I would bet not. Not that I would know for sure, but seeing they are different engine families I'd say they could be different.
Old Jul 5, 2007 | 08:11 PM
390fe's Avatar
390fe
I'd bet a pretty penny the two bellhousings are different. It's quite possible the tranny would bolt up to the FE bellhousing, though.
Old Jul 5, 2007 | 11:31 PM
aMoneypit's Avatar
aMoneypit
Engine to bellhousing bolt pattern and sizes are different, but as mentioned, the manual trannies were pretty much standard pattern. The clutch/flywheel will be different, but as long as the disc spline is the same it should work.....aMP
Old Jul 10, 2007 | 05:46 AM
f700's Avatar
f700
292 to 361
just letting you all no that the bellhouing for the 360 fit in to a 1963 like a glove
Old Jul 10, 2007 | 08:38 PM
aMoneypit's Avatar
aMoneypit
Boy, I'd a bet money on that one. A 292 Y block has the same everything as a FE motor??? Something smells fishy here.........aMP
canyoncat
Large Truck
44
Jan 21, 2022 06:56 AM
Amish Ford
Large Truck
May 1, 2016 07:37 PM
jpenley123
Large Truck
Aug 29, 2011 08:38 PM
idealtrucks
Jun 4, 2004 10:14 PM
Charles-65F350
Mar 19, 2001 09:54 AM
