Sponsored by: Real Truck
powerless injection pump!
Old Jul 1, 2007 | 11:27 PM
sirwallace32k3's Avatar
sirwallace32k3
im new to this site.
I bought a 94 7.3 turbo diesel 2 wheel drive 4 door dually for $550.It had a bad motor.So I bought a motor trans front clip harness and brain out of the exact same truck.I heard the truck run and drive.I did the switch.But i have no power to my injection pump.If I rum a wire to the pump from the battery it will run.Then it stalls,because it has air in the line.I also changed the silenoid on the motor and fender.Please help me from going to the dealership!!!!!!!!!!!!!!!
Old Jul 2, 2007 | 09:46 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE!
You will probably get a faster answer if you ask this question in the early 7.3 forum.
https://www.ford-trucks.com/forums/forum170/
Old Jul 2, 2007 | 09:50 AM
ken kenmnedy's Avatar
ken kenmnedy
check and reset (inernicha)??emergancy fuel cut off switch. ithink its in one of the kick pannels
Old Jul 2, 2007 | 11:07 AM
redford's Avatar
redford
That's true, the inertia switch will cut the power to the fuel pump.
