new flatty question
Old Jul 1, 2007 | 08:00 PM
55 f350's Avatar
55 f350
Question new flatty question
i was just watching an episode of horsepower tv where they were putting togather a flatty . as i am now running a electric fuel pump i was curious as to why they stressed to plug the hole where the fuel pump driveshaft was in the block anyone care to enlighten me before i mess up my flatty ????
Old Jul 1, 2007 | 08:24 PM
4tl8ford's Avatar
4tl8ford
To keep your Oil Pressure where it's supposed to be.
Old Jul 1, 2007 | 08:34 PM
dffay's Avatar
dffay
Your flathead will hemorrhage oil into the valley if it not plugged. All it takes is a pipe thread taper tapping and a hex head plug.
Old Jul 1, 2007 | 09:13 PM
55 f350's Avatar
55 f350
thank you thank you will be fixed asap .
Old Jul 2, 2007 | 12:29 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That is usually only necessary on the 59AB and earlier engines; 8BA's don't have the same problem. Just make sure your bushing is in place.
At the time I converted mine to electric pump, I wasn't sure if I needed to plug it, so I played it safe. Easiest fix (my way, of course) was to cut the pushrod in half, weld a nut on one end, and drop that into the bushing. It can't go anywhere, and I made it short enough to clear the cam lobe. It's just like stock as far as oil thru the bushing.
Old Jul 2, 2007 | 12:49 AM
Snowking's Avatar
Snowking
That would be easier then trying to make something look half decent to fill in the hole for sure.
Old Jul 2, 2007 | 04:45 AM
55 f350's Avatar
55 f350
man you must have been reading my mind albuq as i was just gonna cut mine and either try and musroom the end or weld somethin' on the end instead of looking forever or paying big bucks for a simple plug . well at least i'm on the right track . thanx again guys !
