oil pressure help
Old Jul 2, 2007 | 07:02 AM
Uzumati's Avatar
Uzumati
I wouldn't yet. Just keep an eye on the time it takes the gauge to come up. Also after it has sat overnight check the level in the HPOP reservoir to make sure the anti drainback check valve is not sticking and letting it drain down.
Keep in mind that the way the dual oil systems are designed the truck will stall or fail to start before lube oil pressure gets so low that it will cause damage.
improvement54
15
Dec 30, 2022 02:41 PM
jayton4
Modular V8 (4.6L, 5.4L)
32
May 6, 2013 07:16 AM
Pocket
82
Nov 18, 2009 08:05 AM
Texascadillac42
Jan 10, 2009 12:58 PM
knucklehead11
Bronco II
43
Sep 12, 2003 04:46 PM
