OD light blinking
Old Jul 1, 2007 | 05:22 PM
D Lidren's Avatar
D Lidren
OD light blinking
First post - I have an all stock late 99 F-350 crew cab 7.3. While reading some of the posts I noticed someone mentioned the OD light blinking. A couple of weeks ago my OD light blinked after starting. I didn't notice any apparent problems and it has not done it again. Anyone know what could be the cause & should be conserned? Thanks for any feedback you folks may have.
Old Jul 1, 2007 | 06:07 PM
Izzy351's Avatar
Izzy351
You could try pulling & cleaning the ABS/Speed sensor in the rear-end. It's been known to collect scuzz from the gears and act up. If cleaning doesn't fix it, I believe it's a $10 sensor -- cheap fix.
Old Jul 1, 2007 | 06:08 PM
Izzy351's Avatar
Izzy351
BTW, welcome to FTE! Great bunch of very knowledgeable folks here...
EDIT: (Even though you joined back in Oct '06!!)
Old Jul 1, 2007 | 10:55 PM
D Lidren's Avatar
D Lidren
The sensor is in the differential? If so I will try cleaning it first then change out if that doesn't fix it. Not sure I will know if it is fixxed because it hasn't blinked at me except that one time. Thanks so much for your reply. - Dan.
Old Jul 1, 2007 | 11:17 PM
Izzy351's Avatar
Izzy351
Yep -- it's back there. And you're welcome!! Try not to be such a lurker...
