351W performance rebuild?
Old Oct 30, 2002 | 03:34 PM
Dreau90's Avatar
Dreau90
Post 351W performance rebuild?
I have a 1990 F-150 4x4 with a 351W EFI. I have 186,000 miles on the thing with a leaking rear main seal,leaking timing chaing cover,leaking oil pan, sticking lifters, and I'm sure a huge loss of compression due to worn out gaskets, worn out lobes on cam, etc.
I plan on blue-printing the engine when I rebuild (if nothing else just for the fun of it). I have built several engines with carbs but never with EFI. Basically I don't have a clue what parts combination to use. (i.e. flat top, dome, or stock pistons; high lift roller cam and lifters, performance heads)
If anybody out there has a good combination please let me know.
1. cam and lifter
2. pistons
3. should I upgrade to a high flow intake and throttle body
4. what heads do you suggest.
Keep in mind I want to save all my sensors and stuff so I can use a performance chip. I'd like to see if I could 400 horses out of this thing.
Thanks
Old Nov 1, 2002 | 02:43 PM
Jens's Avatar
Jens
Hi, If you want more power than you need more balance. The most urgent thing when you rebuild the engine is balancing. Check each connecting rod weight and bring them all to on weight so exact as possible. Go ahead with the Pistons, weight them, bring all to the same weight. A good maschine shop sould be able to fine balance the crankshaft. If you have a manual tranny you can loss weight and get power by modifieing the flywheel (lathe).
To the cylinderheads: A good way to get more power is to search a pair of older head, I think the best are build around 1970 with an combustion chamber of 'bout 60 cc. The smaler the chamber so better the power but are the chamber to small you'll have a problem with the gas (knocking). If you have time and the possibility to modify the head it will be great to mesaure each chamber and bring all to the same size.
Here are only a few tips, you can read more in such books like "Hoe to rebuild Ford small Block engines"
If you need more information fell free and contact me via eMail.
Jens
Old Nov 1, 2002 | 03:05 PM
Jens's Avatar
Jens
cdawley4
13
Feb 24, 2011 07:31 PM
qbert
Aug 19, 2010 06:03 PM
Psycho_bob_1977
30
Apr 10, 2004 06:54 PM
ADSf100
Mar 28, 2003 04:59 AM
lt
Feb 27, 2002 01:05 PM
