Sponsored by: Real Truck
30k trans service
Old Jun 30, 2007 | 11:48 AM
someday's Avatar
someday
30k trans service
how many quarts have people changed and which filters? is there a post about servicing the trans?
Old Jun 30, 2007 | 12:02 PM
wlihntr's Avatar
wlihntr
https://www.ford-trucks.com/article/...nsmission.html
Old Jun 30, 2007 | 12:42 PM
someday's Avatar
someday
i read over that article as well but it is not for a torqueshift 5speed...its probably similar but is certainly different since the ts has a remote filter and probably larger fluid capacity
Old Jun 30, 2007 | 01:37 PM
blackhat620's Avatar
blackhat620
Here is the link to the procedure for the Torqueshift, it is in the 6.0 Tech folder.
http://www.truckblog.com/story-582-h...t_transmission
Hope this helps
Old Jun 30, 2007 | 01:40 PM
wlihntr's Avatar
wlihntr
guess you should have let us know what transmission you have...
Old Jul 1, 2007 | 07:54 PM
someday's Avatar
someday
wow, totally forgot about that important info...that is probably why you are the postmaster and i am an elder user
Old Jul 2, 2007 | 12:26 PM
marcussen's Avatar
marcussen
Is the torqshift transmission different on the '08s, the guide for the transmission service shows an external filter mounted close to the radiator, my '08 does not have this filter, at least I can not find it when I follow the lines from the transmission to the cooler (the '08s have the quick disconnects for all the lines going to the coolers, so it is different up front). There is a cannister thing with 4 lines going to it but I thought that was a temperature bypass.
Old Jul 2, 2007 | 08:28 PM
someday's Avatar
someday
i think you found it (canister)...on my 05 e450 it is right next to the trans
Old Jul 3, 2007 | 07:05 AM
marcussen's Avatar
marcussen
It don't look anything like what is shown in the pictures, it's mounted in front of the transmission is shaped like a soupcan and has two lines coming into each end of it.
The owners manual shows two different part numbers Ford FT-176 and Ford FT-175 I am not sure it even has an external filter.
