Chrome/Moly Camshaft? ? ?
Old Nov 12, 2002 | 05:21 PM
FTE Ken's Avatar
FTE Ken
Old Nov 14, 2002 | 04:25 AM
jaimalade's Avatar
jaimalade
Post Chrome/Moly Camshaft? ? ?
Hello All,
I have been diligently looking for a cam core for a MEL that I want to build (can't get teh profile I need out of a re-grind), and I took what I thought was a longshot and called Chet Herbert tonight. Well, at first their cam grinder said that all I can do is a re-grind. However, after I talked with him more and showed that I wasn't just some idiot with an old car and a desire to go fast, he started listening and said that he might have a chome/moly camshaft core for one! He said that he would check for sure tommorrow, and that if he did, that I would just have to find some case hardened lifters. I agreed to call him tommorrow. . .
Now, I know that chrome and moly are two different substances, and that it is either chrome or moly, but nonetheless, I have never heard of such a cam. Is this a billit core? Also, what about these "case hardened lifters"? I guess I am showing my ignorance, but I need a little education here. . .
Also, if there are such things as "case hardened lifters", are there any made for an FE (the MEL and FE lifters will interchange)?
Thanks to any and all that respond,
Nathan
Old Nov 14, 2002 | 06:33 AM
rabidranger's Avatar
rabidranger
I know chrome-moly refers to a steel that has some chromium and molybdinum in it as far as alloying elements. It is a good higher strength steel. I don't know about wear capabilities for chrome-moly though. Case hardening refers to hardening a material to a certain depth. Axle shafts are case hardened. This allows them to remain "soft" in the center and have a hard outside, this prevents them from shattering if they were hardened thruogh. Case hardening may increase the wearability of the lifters. I'll be the first to admit I don't know much about cam shafts, but I have never heard of a chrome-moly one.
Old Nov 14, 2002 | 09:54 AM
Brian's Avatar
Brian
Chrome moly is generally 4130 or 4140 steel. It has well known material properties and is easily hardenable. It is a good material to use in high fatique applications because of its high strength and endurance limit. Typical cams are cast steel I think. It would be the same as comparing a standard cast crank to a billet crank. The billet being able to take high loads.
Old Nov 14, 2002 | 10:42 AM
georgedavila's Avatar
georgedavila
Here's a listing of common steel compositions, courtesy of a poster on the 385 forum. The 4000 series is actually a percentage of molybdenum, while 5000 numbers have a percentage of chromium. Both, plus nickel would be 8000 or both a letter suffix after the primary ID.
Any cast iron (steel) part is just that, molten iron poured into a mould and then machined to final size. A billet steel part is machined from a forged piece of steel; the forging process eleminates air bubbles and irregularities present in a casting process and offers far greater strength.
Those funny #s that designate steel like 4340,5140
UNS classification[unified numbering system]
steels are assigned a series of 4-5 numbers
the first # is the primary element[s]
the second # tells the percent of the first element[s]
the last #s indicate the amont of carbon content in hundreths of a %
1=plain carbon
2=nickel
3=chromium and nickel
4=molybdenum
5=chromium
6=chromium and vanadium
7=tungsten
8=nickel,chromium,molybdenum
9=silicon,maganese
say you have 5040,the first # shows the main alloying
element is chromium.the second #[i know seems confusing "0"]is gona be less than .5% so it gets rounded to 0 so its low chromium.if the % of chromium were .75% the first 2 #s would be 51
50xx=low chomium
51xx=med chomium
52xx=high chromium
the last 2-3 #s are the approximate carbon content of the steel in hundredths of 1 %
so 4340 would be
molybdenum,with approx. 3% molybdenum element and .40% of carbon
d=die steel.air hardening,high chome
h=hot work,chomium,tungsten,and/or molybdenum
t= tungsten alloy,high speed steel
m=molybdenum alloy,high speed steel
l=low alloy,special purpose
f=carbon-tungsten,special purpose
p=mild steel,low carbon,and other types
if anyone has anything to add have at it
Old Nov 14, 2002 | 10:44 AM
georgedavila
The lines through the definitions appeared when the message posted.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
