Hi everyone i have a 1982 f350 2 wheel drive dually the i beams are bent what i need to know is will i beams from a 83 f350 single rear axle be the same or what years will interchange or where i can purchase some
1980/89 F350 2WD Radius Rods are the same = E0TZ-3A360-D
This p/n was also used on 1980/81 F100/150 before build date 8/81 and
1980/86 F250's
1980/82 F350 2WD Axles are the same... R/S - E0TZ-3006-A / L/S - E0TZ-3007-A
but
are different from 1983 and later...(axle stamping numbers are different)
1983/85 F350 2WD Axles are the same. R/S - E4TZ-3006-C / L/S - E4TZ-3007-C
--------------------------------------------------------------------- >> 1980/89 F350's all have the same bolt pattern - 6.50 bolt circle - 8 lug <<
