Range Sensor
Old Jun 29, 2007 | 03:36 PM
mikekin1's Avatar
mikekin1
Exclamation Range Sensor
Does anyone know how much of a pain in the @$$ it is to cahnge a range sensor in a '00 e350 sd???
wont start in park and dealer says it could be range sensor
doesn't seem right though, only has 41,4k on it,nay suggestions welcome
Old Jun 29, 2007 | 06:14 PM
NubVan's Avatar
NubVan
I am sure you checked this but just a suggestion. have you tried to hold the gear selector up as far as you can? possibly the linkage is a bit out of wack?
Old Jun 30, 2007 | 08:05 AM
mikekin1's Avatar
mikekin1
yeah tried that, worked a couple of times but not any more.
could it be something other than range sensor?
going to try to get ford to pay for whatever it is as it seems real strange for this to happen with so few miles. cant afford to have this truck down as its my work truck, any thing that may help that i can do???????
Old Jun 30, 2007 | 03:15 PM
mikekin1's Avatar
mikekin1
any help here???
I could use a few suggestions here range sensor?,linkage?,tranny shot?, short?
Old Jul 1, 2007 | 01:48 PM
87 XLT's Avatar
87 XLT
If yours is setup the same as my 97 Explorer, the transmission range sensor is plugged into the drivers side of the trans with an 11 wire connector..
I presume the shift linkage connects to the sensor.
Old Jul 2, 2007 | 12:56 PM
mikekin1's Avatar
mikekin1
thanks, truck going to dealer to repair thiss week, hopefully that is all that is wrong with it
