I have some ????????
Old Jun 29, 2007 | 09:37 AM
farmlucki's Avatar
farmlucki
Maybe I'm just being over concerned but I noticed the other day that when I have A/C going I'm getting a knocking sound, but when I shut the A/C off it goes away! I just had a 203 thermostate put in along with some guages! O hope I'm not being perioned! Is it supposed to do that or is something wrong!!
One more question, What should be a normal reading for your pyro when it is located post turbo, and how many psi should your boost read when say your cruising about 70 mph. thank you!!!!
Old Jun 29, 2007 | 09:41 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I do not know about the knocking sound. Maybe someone else will know.
As for the EGT and boost numbers....in the stock tune at 70 mph on flat ground I will see about 750 to 800* EGTs and 6-7 pounds of boost.
Old Jun 29, 2007 | 10:03 AM
IDPisan's Avatar
IDPisan
I see about the same numbers as Outlaw, My pyro is pre turbo though
Old Jun 29, 2007 | 10:07 AM
rbaker6336's Avatar
rbaker6336
for knocking check for loose brackets and belt for chips,
once had knocking with york compressor and was compressor about to blow
Old Jun 29, 2007 | 10:14 AM
Texas Outlaw
Not a liberal...
Oops, I forgot he was post turbo. I am pre turbo as well.
Old Jun 29, 2007 | 10:17 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Are you sure it is not the compressor clutck clicking on and off every 10-20 seconds?
For the temp, you should see no more than 600-700 post turbo, and 4-6psi of boost.
Old Jun 29, 2007 | 11:07 AM
farmlucki's Avatar
farmlucki
i belive that is what is, but I just wanted to be sure that it wasn't going to go out on me. It seems to be a little more louder, but it quits when I shut the A/C off! My temp for my pyro has only gotten as high as 600 degrees. The guys that installed it sayed I shouldn't goo over 1200 degrees.
Old Jun 29, 2007 | 11:35 AM
clintbonnie's Avatar
clintbonnie
It sounds to me from what the "guys" said.. your pyro is pre turbo.. If you are post turbo and get a temp reading of 1200 degrees, i believe you are going to melt something.. Can you tell us where they installed the probe?
Old Jun 29, 2007 | 12:20 PM
farmlucki's Avatar
farmlucki
it's on the down tube right behind the turbo! I thought if it was in the down tube you should add a couple hundred degrees versis having it in the manifold!
SilentlySoaring
Oct 6, 2020 09:47 PM
fordtrucklover94
18
Oct 16, 2017 06:56 AM
javi2001
Apr 13, 2009 07:27 PM
ppolewac
15
Jun 1, 2007 01:14 PM
TxFordGuy
1983 - 2012 Ranger & B-Series
Jul 20, 2006 01:25 PM
