transfer case
Old Jun 28, 2007 | 07:30 PM
unluckylow's Avatar
unluckylow
transfer case
Have a 2000 F-250 SD with turn switch 4wd, trying to find out if it is possible to convert current transfer case to manual (lever) or do I just need to swap it for a manual case (lever), and if so where is a good place to find a used one or swap one. Any help would be great thanks Brandon.
Old Jun 28, 2007 | 11:24 PM
rebelchevy02's Avatar
rebelchevy02
Are you having trouble with yours? Or just prefer floor shift? ( i know i do, and i love mine) If you are having trouble, what kinda trouble is it? And does it go away if you manually lock in the hubs?
Old Jun 28, 2007 | 11:38 PM
John311t's Avatar
John311t
IIRC you would need the whole T-case. It may work out to be the same price since the Electric T-case it prolly worth more than the manual, you would also need the floor shifter and mechinisim.
Old Jun 29, 2007 | 08:44 AM
unluckylow's Avatar
unluckylow
Not really having to many problems, I just likw the knowledge when you put the lever in 4wd its in, the electric one sometimes I wonder if its going to go in. I guess I should check junk yrads and look for a one there.
Side note do are there any differences between late model year transfer cases, such as strength, gear ratios. I was was wondering if a different year T-case would bolt up. Just a thought.
wildstang
33
Jul 13, 2021 11:38 PM
Area6567995
WTB - Parts & other
May 5, 2011 05:25 PM
dyhrdford
Sep 23, 2009 10:35 AM
zrt600guy
Offroad & 4x4
Aug 3, 2008 11:05 PM
booker250
Jan 17, 2007 11:04 AM
