Code for door keypad
Old Jun 28, 2007 | 10:18 AM
goatro's Avatar
goatro
I am new to the expedition world. I have a 04 Expedition EB 5.4L and do not
have the code card for the key pad. I know on my SUPERDUTY it was located
under the dash. Also I only have one key for the vehicle. Is there a way I can
reprogam the key my self without going to the stealership to have
reprogrammed. Thanks for any input.
Old Jun 28, 2007 | 10:48 AM
04markIII's Avatar
04markIII
key issue: you have to go to dealer if you only have one working key.
code issue: while at the dealer, have them grab the code from the computer they will use to program a new key. shouldn't cost any extra because they are alreay using the computer.
Old Jun 28, 2007 | 10:56 AM
goatro's Avatar
goatro
Talking
I actually found the keypad code after tearing off some panels in the truck.
It was behind the fuse panel on the passenger side(kick panel) up high and to
the left. The key part really sucks. Thanks 04MarkIII.
Old Jun 28, 2007 | 11:52 AM
04markIII's Avatar
04markIII
no problem. i work at a dealership, so i have the info available!
Old Jun 28, 2007 | 06:07 PM
ChipD's Avatar
ChipD
Try searching the Expy forum for the door kepad code location. There have been a number of posts in the pasts that identify exactly where you can locate the code by looking underneath the dash board.
Old Jun 29, 2007 | 07:44 AM
04markIII's Avatar
04markIII
looks to be all set.
Old Jun 29, 2007 | 11:36 AM
2000Expy's Avatar
2000Expy
A new key and remote programmed at dealer is about $130. Nice, huh? Get a spare set on ebay and have the key cut on a normal key cutter, then program it yourself using your two other keys. Secure third set in safe place.
Old Jun 29, 2007 | 03:03 PM
Sanchez_315er's Avatar
Sanchez_315er
Explain please...
Old Jun 29, 2007 | 05:08 PM
goatro's Avatar
goatro
I called the dealer and got a quote. One key and reprogram is 112.00 plus tax.
Just to program if I have my own key is 69.00 and the key was 43.00.
I looked on ebay and found keys for 15.00 each. I may go the route of
cutting my own keys and bring in for a program.
In the owners manual it tells you how to add up to five additional keys.
