351M backfiring through carb
Old Dec 20, 2011 | 11:44 AM
mark a.'s Avatar
mark a.
I'd check the preload on every lifter when you have it apart. Most of the time you can't just get away with throwing a cam in and expecting it to work. Most all aftermarket performance cams have a different base circle that will cause preload problems that can act as you have described.
Old Dec 20, 2011 | 08:14 PM
crsmiffy's Avatar
crsmiffy
"I'd check the preload on every lifter when you have it apart. Most of the time you can't just get away with throwing a cam in and expecting it to work. Most all aftermarket performance cams have a different base circle that will cause preload problems that can act as you have described. "
__________________
I believe that you wrote you had a rebuild book. If it's tom monroes excellent tome it mentions how to check the preload on the lifters. You may have to shim some/all/none of them, or as I had to do grudgingly remove some material from either the rocker mount on the head (pain) or from the rocker sled (what I did) as it had too much clearance.
LipRipper3006
16
Aug 1, 2017 11:22 AM
hail destroyer
Oct 2, 2016 06:32 PM
hail destroyer
Sep 24, 2016 10:57 PM
Buyerz
Jul 11, 2016 12:37 PM
manlikesford
Feb 2, 2013 10:06 PM
