won't start
Old Jun 27, 2007 | 05:43 PM
mcguffee's Avatar
mcguffee
Smile won't start
I could not get my 95 7.3 to start after shutting it off. had a burnt plug on harness at valve cover. replaced eng harness, valve cover gasket, cmp, o-rings on injector reg valve on hpop, test oil pressure on right bank . none! put both hpop lines together and had 800 to 900 while cranking. plugged r-side at hpop and tried . it started on one bank and jumped past 2500 psi, I shut off and plugged l-side at hpop and had 0 psi. my guage only read in 100 psi marks. pulled p-side valve cover and cranked eng , oil ran out the 3rd injector. pulled and found top o-rings blown, all 8 were rebuilt about 8000 miles ago. I would of never thought to check this except that a ford truck mechanic told me to look for the oil running out injector. thursday I will get o-rings. I hope this helps someone , I know reading some of the post helped me.
Old Jun 28, 2007 | 06:14 AM
Cuda_jim's Avatar
Cuda_jim
Thanks for the heads-up. I hope you get it fixed. Keep us posted on your progress.
Old Jun 28, 2007 | 10:34 AM
Neal 97 250's Avatar
Neal 97 250
It is alwqays great to hear news like this. You fixed it and let us know for future reference. Thanx.
Old Jun 28, 2007 | 11:32 AM
tjbeggs's Avatar
tjbeggs
Thanks for the info! Good to see a new guy already contributing to the forum! Rep pionts sent!
