Fuel Injected Vs 1bbl
Old Jun 26, 2007 | 04:40 PM
shotime91's Avatar
shotime91
I just bought a 75 f250 with the one barrel straight 6-the engine has about 20 to 30 thousand kms on it since rebuild-runs good-good power.
Question-
Will the fuel injected setup from a 1987 300 bolt to the older 75 engine and if it does will it be a better system-or should the the complete 87 engine be swapped in to accept the fuel injection
which one makes more power?
Old Jun 26, 2007 | 07:53 PM
javi2001's Avatar
javi2001
Ok let's do it one by one...
Will the fuel injected setup from a 1987 300 bolt to the older 75 engine Should fit since the bolt pattern used at head is same, but probably the knock sensor location needs some thread job.
...if it does will it be a better system? Yes! dyno number verify the EFI setup produce a bit more of power than stock carby setup.
which one makes more power? EFI as mention previously because it breath better
Try to find an EFI setup from a F150 1991, will be the best for your '75 without to much electrical job OR...
Get and aftermarket intake, 2 barrel carby, EFI exhaust setup, Crane Cam and it will rock better than stock EFI
Old Jun 26, 2007 | 11:19 PM
shotime91's Avatar
shotime91
thank you-think I will leave carb setup!
grip1968
Sep 3, 2012 11:42 AM
parkland
General Diesel Discussion
71
Mar 31, 2012 11:37 PM
thedaddycat
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Apr 5, 2008 12:42 PM
Pettybonz
Mar 15, 2005 11:22 AM
eigenvector
1983 - 2012 Ranger & B-Series
Nov 4, 2003 09:47 AM
