Gear ratio question
Old Jun 26, 2007 | 08:21 AM
jeffnoel's Avatar
jeffnoel
Question Gear ratio question
Is the a tag or sticker somewere on my 99 Expi 4x4 that tells me the rear ratio in my diffs?
Old Jun 27, 2007 | 07:54 AM
merczephyr's Avatar
merczephyr
Look on the VIN sticker on your drivers door. Along the bottom you should find several codes. Look for "AX" with a number and a letter under it. Do a search for rear axle codes here, and you should find it. Or post it up here and I'm sure someone should decode it for you.
There should be a metal tag on one of the bolts that hold the rear diff cover on. It should have the info as well. Hopefully it won't be like mine and unreadable.
