Modular V10 (6.8l)
Spark plug question
Old Jun 26, 2007 | 07:55 AM
BadHabitinVA's Avatar
BadHabitinVA
Spark plug question
I have an '04 with 51K on it.
I'm reading where a lot of guys are changing their plugs prior to the 100K mark. I've had two 5.4L's that went the 100K, and my companies 4.6L Expedition did as well.
What say you gurus?
Old Jun 26, 2007 | 08:18 AM
Fredvon4's Avatar
Fredvon4
Most of us say 3 years or 30~50 thousand miles max.... we are more concerned with corrosion, and heat cycle loosening, then longevity of the plug gap
Most of us agree that Fords 100K "tune up" interval is silly and catastrophically dangerous
Most of us also agree that stock heat range Autolite or MotorCraft plugs (new style with anti corrosion plating) is the way to go
Old Jun 26, 2007 | 09:55 AM
metalman1320's Avatar
metalman1320
I changed mine right after I bought my truck w/ 41k on the clock. All the plugs were tight, clean, w/ no signs of corrosion. It made me feel better knowing everything was tight and new, seeing as how I had no maintenance history on this thing. To go 100k is just asking for trouble IMO, I don't care what Ford or anyone else says.
I used Autolite Platinum plugs and I replaced the boots w/ Napa pieces while I was in there. No sense changing the plugs and not the boots. A little anti-sieze on the threads of the plugs, a dab of dielectric grease in each end of the boots, 168 in/lbs of torque and your good to go!! Oh and don't forget to blow the holes out w/ air as your removing the plugs to keep everything clean.
And I plan on changing them again at 75k, just in case anyone's curious.
Old Jun 26, 2007 | 10:03 AM
BadHabitinVA
How hard is it to change the boots? Any procedure?
Old Jun 26, 2007 | 10:13 AM
metalman1320
When you remove the screw that holds the COP, you'll pull it up and the boot will be attached to the bottom of the it. The boot may stay attached to the plug, as I had a few do this. Just pull up on it and it will come right off. It has a spring inside of it, which is how the spark energy reaches the plug from the COP. I recommend changing these w/ the plugs as I had one spring in particular that was really stuck to the plug. As I pulled on it, it stretched beyond recognition. I don't think it would have worked very well after that.
Changing the boots w/ the plugs is just cheap insurance.
Old Jun 26, 2007 | 10:15 AM
BadHabitinVA
I thank you for that info...I assume these are sold at parts stores?
Old Jun 26, 2007 | 10:22 AM
metalman1320
Yeah, I bought everything, plugs and boots, from Napa. The boots will come w/ new springs. Just make sure they sell you 10 of them. They intially tried to sell me a "kit" w/ just 8 and then sell me 2 kit's. I found the p/n on their website for the individual boot's and springs and just ordered 10 of them.
Good luck!!
FordLou
1997 - 2003 F150
Apr 14, 2015 10:16 PM
Platinum08
Modular V8 (4.6L, 5.4L)
Jul 6, 2014 05:24 AM
Jerry Hardman
1997 - 2003 F150
Jan 14, 2014 03:49 AM
4.9L
Aug 12, 2013 08:48 PM
hendedo
2004 - 2008 F150
Jan 5, 2012 11:56 AM
