Modular V10 (6.8l)
Why is the compression ratio so low?
Old Jun 25, 2007 | 09:02 PM
the Goat's Avatar
the Goat
<meta http-equiv="CONTENT-TYPE" content="text/html; charset=utf-8"><title></title><meta name="GENERATOR" content="OpenOffice.org 2.0 (Linux)"><meta name="AUTHOR" content="Ryan Patterson"><meta name="CREATED" content="20070625;21134300"><meta name="CHANGEDBY" content="Ryan Patterson"><meta name="CHANGED" content="20070625;21442800"><style type="text/css"></style>I'm looking at the 2008 superduty book my dealer gave me and it lists the trition v8 compression ratio to be 9.8:1 and the triton v10 compression ratio is 9.2:1. The bore and stroke are the same. I thought the v10 was basically the v8 with two extra pistons. Why does ford drop the compression ratio down when adding the extra two cylinders? The best I can come up with is it makes the engine more super/turbocharger friendly. But that can't be the reason. If the v8 can handle 9.8:1 compression shouldn't the v10 be able to handle the same? Wouldn't keeping the compression higher allow the v10 to produce more power and be more efficent? I'm sure ford knows what they are doing so there must be a good reason.
Old Jun 25, 2007 | 09:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
Read.
https://www.ford-trucks.com/forums/5...n-why-how.html
Old Jun 26, 2007 | 06:49 AM
the Goat's Avatar
the Goat
Originally Posted by Monsta
Thanks. Hah, they arrived at the same conclusion I did "boost".
Old Jun 26, 2007 | 08:28 AM
Fredvon4's Avatar
Fredvon4
There is a serious difference between "static" and "dynamic" compression ratios
Ford's static numbers are simple math based on cylinder volume at BDC vs cylinder volume at TDC
Dynamic compression ratio considers valve timing, overlap, and the extra 2 cylinders load on the various other systems (starting system as an example)
compression ratios relate to more then just cylinder timing/firing sequences and pre ignition... the engineers also consider bore evacuation, pre fill, shape, charge injection velocity and about another half dozen factors to arrive at a formula for decent drive-ability, starting, volumetric efficiency etc...
To compare the modular 5.4 to the 6.8 is interesting but not really relevant --- IMO --- The 6.8 is NOT just a v8 with two extra cylinders...intertnal combustion motor engineering is much more complicated then that
Old Jun 26, 2007 | 11:05 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Don't forget, the 5.4L is now VVT - variable valve (cam) timing
The V10 is NOT.
So, like Fred said, dynamic compression is different between the 5.4 and the V10.
edisonranger
Sep 13, 2021 02:59 PM
WE3ZS
Feb 20, 2017 11:54 PM
nascar6dude
2004 - 2008 F150
May 19, 2012 01:48 PM
okiedooo
Apr 22, 2007 06:50 AM
bterry
Modular V10 (6.8l)
Feb 1, 2006 07:10 PM
