Sponsored by: Real Truck
Ginding Noise?
Old Jun 25, 2007 | 10:23 PM
shurbs2004's Avatar
shurbs2004
Question Ginding Noise?
I have a 2004 F250 with 85,000 miles. Just the other day I noticed that my truck started making this grinding noise and I thought it was just the pavement. Now I have heard it another 2 or 3 times in past couple days. Anyone have any ideas? It almost sounds the brake pads gringing but I dont think that is what it is. Thanks
Old Jun 25, 2007 | 11:07 PM
Todder's Avatar
Todder
Did you check your rotars to make sure its not the breaks? Maybe a carrier bearing? Bad front hub? I would beat on the hub honestly.
Old Jun 25, 2007 | 11:56 PM
blackhat620's Avatar
blackhat620
More than likely the front wheel bearings. They are a sealed non-serviceable unit. You can replace with factory sealed units or upgrade to the "Dyna-Trac Freespin" kit
www.dynatrac.com/products_freespin_ford.html
Old Jun 26, 2007 | 08:42 AM
redford's Avatar
redford
FTE Leadership Emeritus
To check and see if it your front hubs, lock the hubs without putting the truck into 4 wheel drive by turning the hubs. Now drive the truck and see if you can hear the grinding. If not, it's probably the hubs causing your problem. (As long as you don't put it in 4H or 4L you won't hurt anything)
It is a fairly common failure for these trucks. As blackhat620 stated, the hubs are not serviceable, they are replaced as a unit. The Dynatrac kit he mentioned corrects that problem but isn't cheap.
If it only happens when you apply the brakes, then it is probably the brakes.
It could also be the carrier bearing (if you have a long wheelbase truck) or even U-joints.
Old Jun 26, 2007 | 09:43 AM
rbaker6336's Avatar
rbaker6336
somehow these are repairable a friend had one go out and the shop put bearings in it
BTW this hub only had about 5000 mi since new
Old Jun 27, 2007 | 11:21 AM
shurbs2004's Avatar
shurbs2004
Okay now that it has been doing it a little more, it sounds more like something is loose. When i hit a bump it sounds like something is shaking like metal touching metal for anywhere from 1 to 10 second intervals, then when i hit another bump or change lanes it stops. Any help from anyone that has had any problems like this would help me to know where to start looking under the truck for something loose. Thanks
Old Jun 27, 2007 | 01:40 PM
redford's Avatar
redford
Not in a Ford Super Duty hub, unless he has the freewheel conversion kit.
Old Jun 27, 2007 | 01:41 PM
redford's Avatar
redford
Check your brakes and your ball joints.
Old Jun 27, 2007 | 02:38 PM
rbaker6336's Avatar
rbaker6336
no conversion stock '99 f250 4x4
yes it was done
Kelceykzk
Oct 8, 2013 11:46 PM
edford1
Jul 8, 2013 06:13 PM
Flash1034
2004 - 2008 F150
Jul 15, 2009 09:19 PM
gard107
Jan 8, 2009 03:43 PM
RJs2004
Mar 31, 2007 07:49 PM
