Unless you have A/C and power windows I'd say 80 Amps is plenty. The one-wires are okay with less wiring involved but cost more and not as available. The 3-wires can be had for much less money but require more wiring and available at any parts house. If yours is already set up with a 3-wire I'd keep it.
GNW has a point. Unless you plan on running a bunch of tech-no **** 80 amps is more than plenty. Im a very simple kinda guy and in my opinion id spend the extra $$$ to find a 1-wire.....But like everything else, its your truck, your decision...
I used a GM 1 wire on my 302 and just had to add a spacer on the main pivot bolt. That was the only difference tween the GM and FORD versions. 'bout a 1" or so spacer.
What's wrong with a Ford alternator??? The GM is used on flatheads and Y-blocks only because there isn't any Ford alternator that came stock on them, so everything is going to be "custom". Why go to anything but the OEM piece, that you could have installed in 15 minutes??
Watch out for the size of an 80 amp alternator over the usual 45, 55 and 65 amp alternators Ford used beginning in 1965. Some of the 80 amp alternators are much larger in diameter and require special brackets. The brackets that Ford used for the other less amperage alternators are pretty much universal.
