Tom, the reason why your diesel tach didn't work is because the diesel tach is set up for an 8 cylinder. You have a 6 cylinder. That's why it only read 20%.
Yeah, I thought that might have something to do with it. Of course I have seen where a guy swapped a cummins into a 92-96 Bronco and got a factory diesel tach to work. I'm sure he did a little more than just plug the ford harness into the cummins, though!
He had to have worked some magic. Seeing how these trucks didn't come with 6 cylinder diesels, a factory diesel tach wouldn't work with it. I could see getting a tach that was used with a 300-6 working with the Cummins. But any other way I don't think is possible...
That's the thing: any gas tach will work in any gas truck, doesn't matter if its a 6 or an 8. And a diesel tach will work in a 8 cylinder truck but not a 6. I don't get it.
I don't think a gas tach from a 6 cylinder will work with an 8 cylinder or vice versa. The tach doesn't know what engine it's reading from. All it does is recieve pulses. I think it comes down to the theory that 6 cylinder tachs will work together, and 8 cylinder tachs will work together, reguardless of rather or not its gas or diesel.
I'd beg to differ. The salvage yard I bought my current tach from listed it as from a 351 (might've been a 302, but definitely not a 300) and on the back of the circuit board it has an '6-8' or something like that. According to my math, it reads pretty close to what it should: 2100-2200 at 70pmh with an M5OD, 3.55s, and 31s. I'd be more than happy to swap with someone near atlanta with a v8 to see for sure. Anything in the pursuit of the truth!
lostin90s, read my original post first. You will see that he and I already have a gas tach. We both want diesel tachs.
Hi I'm just saying I know a electrical engineer that spent 3 months playing with diesel cluster for in his truck just becuase he was to cheap to buy a gas one . And never got it to work right . So read my post got gas get gas . The lower rpm on it wont keep those guys you worrie about from beating on truck.
I appreciate your help. I got the cluster today and noticed right off the bat that the tach has 3 prongs vs the 4 on the gas tach. I emailed a buddy who had done this previously (and yes, he did get it to work) to see how he got his working. Mine will kick on, but when you fire it up, it will slowly just do a revolution until it points straight down. I'll keep ya'll posted...
