1978 - 1996 Big Bronco
Topless
Old Jun 24, 2007 | 08:52 PM
roostercrows's Avatar
roostercrows
Topless
I'm going to go topless for the first time, and I was wondering how everyone stores theirs when its off. I have no garage, and the inside of my top is finished ( fabric and such). I plan on leaving it off for a few weeks and I am concerned about bugs and moisture damage. Should I wrap it? or what? I might be able to get it into a storage shed if its not to heavy for two of us to get it through a man door, but only if it can take standing up against the wall on a 45* angle. What kind of weight am I looking at as well? Any help in this matter would be much appreciated.
Thanks
James
Old Jun 24, 2007 | 09:25 PM
96eddie5.8's Avatar
96eddie5.8
i believe 120lbs was quoted as the weight, and it should be stored flat. i would think the fiberglass would break if it was set on one of its edges.
it was discussed in detail here:
https://www.ford-trucks.com/forums/6...?highlight=top
Old Jun 24, 2007 | 09:33 PM
roostercrows
thanks 96eddie, that doesn't sound too bad, I was told the weight was upward of 300# so thats a relief, but i still need storage tips for outside.
James
Old Jun 24, 2007 | 09:37 PM
Zip's Avatar
Zip
When I had my 81 I would back up to my deck drop the tailgate, get myself centered under the top an walk it off onto the deck. If I can do that I don't think they are all that heavy. If I remember correctly it was lighter than the one on my 66.
Old Jun 25, 2007 | 08:24 PM
roostercrows
well thats good news! i'm glad that its light, so what is the best way to store it outside?
Old Jun 25, 2007 | 09:35 PM
Aciancio's Avatar
Aciancio
The top is only 120# and if easy to take off. I suggest using two people. Now you have to set it on blocks to keep the seals off the ground. If you are worried about water you might throw a tarp over it
Old Jun 26, 2007 | 11:42 AM
MBBFord's Avatar
MBBFord
I usually don't leave it off for long, so I just put it on the ground untill I put it back on.
Best thing to do would be put it on blocks(4x4s as long as the top)on each side and put a tarp over it, and weight down the tarps edges.
Old Jun 26, 2007 | 07:09 PM
roostercrows
does any one know what size of torx bit is needed for the 3 point belts?
Old Jun 26, 2007 | 07:19 PM
MBBFord's Avatar
MBBFord
Don't go out and buy on yet, but I'm pretty sure it's a T50.
Old Jun 28, 2007 | 03:22 PM
wileec's Avatar
wileec
I think it is T40 (be sure to get a security bit) one with a hole. Alos I have stored min leaning against a waal every summer for the last 13 years I set it on the back corners or for a few years I put 4x4s under the edges to protect the corner. Never had any problems with the top or leaking. It has now been sitting that way for 3 years since I got the soft top.
Old Jun 28, 2007 | 08:16 PM
96eddie5.8's Avatar
96eddie5.8
t40 security for the top and i believe t50 for the belts, which i know both are correct because i just looked in the tool box.
Old Jun 29, 2007 | 06:54 PM
greystreak92's Avatar
greystreak92
You can skip the "tamper-proof" version of the T40 Torx driver if you are willing to take a punch and snap out the center pins in the bolt heads. Otherwise T40 tamper-proof Torx as the guys have already mentioned.
Old Jun 30, 2007 | 09:42 PM
roostercrows
Thanks guys for everything, I found a set of security bits for $30 and took off the top!
It went very well, that top is something awkward though. I stored it on my deck which will be temporary until I can find a better spot. Anyway I'll take some pics and post them soon!
James
Old Jul 1, 2007 | 08:16 PM
roostercrows
Here's the pics. What do you think?
Old Jul 1, 2007 | 08:47 PM
dcf4x4's Avatar
dcf4x4
That's a beautiful sight!
You're a lucky guy.
