2001 Front Parking Light Bulb Replacement - How
Old Jun 24, 2007 | 06:39 PM
vision976's Avatar
vision976
Angry 2001 Front Parking Light Bulb Replacement - How
Bought a used 1998 Ranger 4x4 that had been wrecked and rebuilt with a 2001 front end. It has a burned out parking light on the front driver's side. I have a full set of factory 1998 shop manuals, but they do not apply to the front end on this truck.
How do I go about replacing the parking light bulb?
I've spent a little bit of time unscrewing plastic (the grill) but can't figure it out.
Thanks.
Old Jun 24, 2007 | 08:24 PM
FTE Trigger's Avatar
FTE Trigger
I found the instructions... but its quite detailed...
It was found here... https://www.fleet.ford.com/maintenan...ls/default.asp
you could also go to motorcraft.com and click on "Technical Resources" across the top header bar and then to "Owners Guides" (?)
Old Jun 24, 2007 | 09:49 PM
Rockledge's Avatar
Rockledge
Trigger's idea is a good one. You can find the instructions in an '01 Owners Manual.
http://www.fleet.ford.com/maintenanc...ls/default.asp
Old Jun 24, 2007 | 09:50 PM
vision976's Avatar
vision976
The Motocraft site had a 2001 user guide with instructions that were sufficient. Thank you.
