Sponsored by: Real Truck
lighting
Old Jun 24, 2007 | 03:58 PM
carls 250's Avatar
carls 250
lighting
anybody using LED lighting for stop/turn sig. & marker lights.I have lights set up so they are on any time ign, is on,so bulbs burn out quite often.
Old Jun 24, 2007 | 04:33 PM
ReAX's Avatar
ReAX
Domestic turn signal systems don't generally like LED bulbs. LED's pull very little current, to make it work you will need to find an electronic flasher. Something like these http://www.thehoffmangroup.com/KeepI...s_RELAYS.lasso
Also remember that incandescent lights emit light in a way that reflects off of the housing. LEDs emit a much narrow beam of light and don't generally light the entire housing.
Old Jun 24, 2007 | 09:45 PM
RACERX7775's Avatar
RACERX7775
i changed the rear lights on my X. i cut the housing and fabbed in a 4" tractor trailer light that is led's. pics in my gallery.. works great.
Old Jun 25, 2007 | 06:06 AM
bigskymt's Avatar
bigskymt
I'm running these and are happy with them so far. Install was about 5 minutes total.
http://cgi.ebay.com/ebaymotors/ws/eB...0210448&rd=1,1
Old Jun 25, 2007 | 09:03 PM
RACERX7775's Avatar
RACERX7775
those look really cool. i dont like the ones they have for the excursions. there are only like 2 styles for mine.
Old Jun 26, 2007 | 09:09 AM
Beerstalker's Avatar
Beerstalker
Recon has LED mirror lights and 3rd brake lights available right now. They are supposed to be coming out with taillights next month. They also have replacement cab lenses, with amber bulbs, but they are not LED. They are a very popular size though so you could probably find an LED replacement bulb. Like ReAx mentioned though, you will most likely have to change out your flasher relay as the lower resistance will mess up the blink rate (they will flash really fast like if you had a bulb burned out).
Here is a link to Recon's website.
http://www.gosocom.com/
Old Jun 26, 2007 | 09:18 AM
RACERX7775's Avatar
RACERX7775
since i already have led's fabbed into my factory tail lights, i dont have to worry about flasher issues. i have my stock flasher. i just have resistors wired inline to compensate for the lower load on the circuit. but thanks, i'll wait for the new ones to come out.
Old Jun 26, 2007 | 09:24 AM
bbender85's Avatar
bbender85
i run these in my stock taillights:
http://cgi.ebay.com/ebaymotors/3157-...34310723QQrdZ1
and the same in amber up front. they fill the reflectors as good as or better than the incandescent bulbs, and i LOVE how they turn off and on faster than the incandescents... and they also match my Recon 3rd brake light.
i just installed an elcetronic flasher in place of the factory one under the dash...$12 and no flashing issues at all.
Old Jun 27, 2007 | 02:41 AM
GregsSD's Avatar
GregsSD
If you are looking for LED replacement bulbs, this site has replacements for everything: http://autolumination.com/3157_3156.htm
For my taillights, I cut out the back of the housing and added some oval truck/trailer LED lights and they are bright:
Here's with the taillights on:
And here's with the brakelights on:
Old Jun 27, 2007 | 02:52 PM
SpringerPop's Avatar
SpringerPop
Got a photo of what the back (fabbed) side looks like?
Any waterproofing issues?
Pop
Old Jun 28, 2007 | 12:27 AM
GregsSD's Avatar
GregsSD
Pop
Here is a picture of the backside after I cut it out for the light:
And here is the light in position (the electrical tape is just to hold it in the correct position). I then used black silicone to seal it and hold it permanent. I did this several months ago and have had no problems with water getting in.
Old Jun 28, 2007 | 04:27 PM
ryaneverk2's Avatar
ryaneverk2
I also cut my taillight housings, and mounted truck-lite model 60 LED lamps. Got them via ebay for $35 for the pair. I used a gel epoxy to seal them in place. A dremel tool works well for cutting the piece out of the stock reflector.
http://rides.webshots.com/photo/2878...86590301tcqkpE
Old Jun 28, 2007 | 04:50 PM
bbender85's Avatar
bbender85
man, you guys did it the hard way!! looks good though.
FWIW, i did both taillights, both front blinkers, side markers, plate bulbs, and all 3 3rd brake light bulbs all in LED for less than $60 shipped... with no cutting involved. maybe i cheat, lol.
Old Jun 29, 2007 | 08:08 PM
RACERX7775's Avatar
RACERX7775
yeah, but just replacing your factory bulbs with the plug in led versions isn't worth it. they are no way near as bright as the led assemblies that we are using.
Old Jun 29, 2007 | 09:27 PM
bbender85's Avatar
bbender85
have you seen the style i have in person? they're not like the crappy directional LED's autozone has.. i had those in a previous vehicle, THAT was a mistake, haha.
