New guy on the block
Old Jun 23, 2007 | 05:52 PM
phxboy's Avatar
phxboy
Ford Man through and through................
Old Jun 23, 2007 | 06:00 PM
khadma's Avatar
khadma
Carpenter Local 745
Is that so? That's what they all say until you read their signatures .
Welcome to FTE, be ready for a new way of "life", you'll see.
This is a great site, you will see that we are not just Ford guys and gals, but loose nuts behind the wheel. Some guys own/owned every type of car/truck/MC on the face of the planet. Most know alot about Ford trucks, that's why we/you are here. There is plenty of info and funny posts to read too. Have fun.
Old Jun 23, 2007 | 06:11 PM
phxboy's Avatar
phxboy
Wondering why my F350 Diesel is having a problem
I have an 2006 Ford F350 Diesel 6.0, I am having an issue with the engine shuting down at times. The engine slows way down to a purr, then the engine has no power to pick up any speed. I can not equate this to a change in elevation, heat or weight of a load when I have towed. The first time this happened, i was hauling over 15,000lbs. uphill, the truck lost power and we had to pull to the side of the road to let the engine revamp. Now, the truck seems to be doing this at random, just around town not pulling a load. (temp. gauge does not change with this either).
I am at a point that I am confused as there are no codes, it comes up clean when I have had it at the dealer for this problem.
Is anyone out there having any of this problem or can give me an insight to what may be causing this?
Old Jun 23, 2007 | 06:12 PM
phxboy's Avatar
phxboy
<TABLE><TBODY><TR><TD vAlign=top width="100%">I have an 2006 Ford F350 Diesel 6.0, I am having an issue with the engine shuting down at times. The engine slows way down to a purr, then the engine has no power to pick up any speed. I can not equate this to a change in elevation, heat or weight of a load when I have towed. The first time this happened, i was hauling over 15,000lbs. uphill, the truck lost power and we had to pull to the side of the road to let the engine revamp. Now, the truck seems to be doing this at random, just around town not pulling a load. (temp. gauge does not change with this either).
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE><!-- / message --><!-- no sigs except when logged in --><!-- sig -->
__________________
Old Jun 23, 2007 | 06:15 PM
khadma's Avatar
khadma
Carpenter Local 745
head for the 6.0 forum, you will get plenty of help there.
at the home page. look under the FTE banner, in the grey bar there will be forums at the left. put your cursor there, it will drop and click on list, scroll down to diesel forum and you can figure out the rest.
Richie hollis
New Member Introductions
Aug 19, 2018 08:59 AM
dochall
Feb 15, 2016 01:27 PM
dinosaurfan
Dec 23, 2001 10:32 PM
