Burnin oil ?
Old Jun 23, 2007 | 05:42 PM
Benny2002's Avatar
Benny2002
Burnin oil ?
How much oil are fellow FTEs burning in say 1 oil change or 4-5K miles. I just freaked out when i changed my oil, and normally i check the stick every other tank of fuel, i drive ALOTTT. When i was returning my oil to the new bottles i only ended up with about 13 quarts. Last oil change i didnt burn that much, hot weather???
Old Jun 23, 2007 | 05:50 PM
Benny2002's Avatar
Benny2002
bummmmmmmp
Old Jun 23, 2007 | 05:51 PM
Pocket's Avatar
Pocket
Considering your truck holds around 15 quarts, and you normally can only drain/refill about 14 quarts, you aren't doing bad at all to be 1 quart shy on a 4-5K mile oil change. There's plenty of folks out there who use way more than that. Ford won't fix anything unless you are burning more than 1 quart every 900 miles.
Old Jun 23, 2007 | 05:52 PM
Benny2002's Avatar
Benny2002
Nice, Thanks Curtis
Old Jun 23, 2007 | 06:06 PM
rebelchevy02's Avatar
rebelchevy02
My 02 with 145k eats about 1-3 quarts every 7-8k. Not too shabby i dont believe
Old Jun 23, 2007 | 06:09 PM
rbaker6336's Avatar
rbaker6336
sometimes mine will use 2qt in 1500 mi sometimes 2qt in 5000 mi same drivin
119k mi
Old Jun 23, 2007 | 06:49 PM
bdrummonds's Avatar
bdrummonds
if towing 5er 1 quart in 3k ( I consider 12k#s severe duty so I change oil at 3k while towing) or normal driving (no towing) less than a quart in 6k miles.
