Computer Chips & Tuners
can superchips be programmed?
Old Jan 14, 2001 | 10:51 PM
forddog's Avatar
forddog
I have a 92 F-150 with a 302. I recently swapped the stock 3.55 gears out and installed 4.10's with 33x12.50x15 BFG MT. I have a couple of questions regarding a custom programmed chip? First do I need to customize the chip for the new gear ratio and bigger tires or will a regular chip work just fine? Second do I even need to worry about changing any thing to recalabrate for the new gears. I know that the OBDI controls timing, fuel, and spark, but are they programmed with axle gear ratios? I have heard that the superchip is the best chip to buy for my Ford. I just want to make sure I cover all the bases before buying One.
Thanks for any info.
Forddog
Old Jan 15, 2001 | 07:27 AM
D's Avatar
D
FordDog: My suggestion would be to try a stock chip first. The only thing that a custom program would do, is correct for the speedo reading. The truck should run and shift just fine with the stock program, if not, then we can have a custom program written and added to your chip.
Thanks
Danny
Old Mar 5, 2001 | 09:20 AM
traildawg's Avatar
traildawg
FordDog, I just read somewhere on here last week about how to recalibrate your your speedometer yourself. I think it was in either the Off-Road or Suspension, wheel, and tire forum.
TrailDawg
1993 F150 2WD
4.9L-Auto
Pro-Comp Stage-2 6" lift
Auburn Pro-Series Diff. w/4.56:1 gears
35x12.50x15 General Grabber MT's
Old Mar 6, 2001 | 07:17 AM
D's Avatar
D
echoy97
Escape & Escape Hybrid
17
Dec 22, 2004 10:34 AM
boxcar1974
Jan 30, 2004 04:31 PM
mrak
Nov 21, 2003 11:03 AM
FTE Ken
Site Announcements
Apr 10, 2002 08:57 AM
beaverhunter
Jul 2, 2001 01:09 PM
